Megasquirt EFI and Ignition Project
  • #31
    There are many different ways to do the ignition. I'm going with a 3.5" 36-1 toothed wheel and a Ford VR sensor.
    All ignition options can be found on THIS PAGE here. It's a bit heavy going
    '84 Sport
    • #32
      I wasn't going to pull this thread back up just yet, but since you guys have already done it... I am really enjoying the tuning process.
      So, let me update a little. I was having NO luck with the Automatic Mixture Control. I don't know why, but absolutely NOTHING was happening. Probably user error. So, I decided to use a program that is available for free called MegaLogViewer. It is quite fun. I strap the laptop to the back of the bike, start datalogging, and then go ride the crap out of it for about 15 minutes trying to capture as many diving conditions as I can. In areas where it feels like there are issues I focus in and try to get lots of data feedback. Then I pull over somewhere, and shut down the bike. I open MLV and open the datalog in it. I click a couple buttons and it analyzes the datalog and then shows you the recommened changes to the VE table. I save the changes, burn them to the MS unit and then take off for some more datalogging. I took a run last night and decided to really give it a go. I am pretty sure the front tire came off of the ground when I took off in first. I am very surprised at the low end power. I wasn't expecting much due to the larger bore of the TB's and the addition of the 70's intake cam. I am definately noting an all around increase in power and I haven't even got it all tuned yet. I will be testing the milage soon and will report. So far, it seems as though the little fuel pump is performing well. I am going to barrow an inline gauge to do a final test and then call it good and mount it properly. I will get some more pics and maybe some video soon.
      Oh, and one last thing. For all those who think that syncing the carbs is challenging. It is a cake walk compared to the throttle bodies. This is due to the fact that the cable attatches outside the #4 TB. So, the other three are set to the #4. It took a LONG time to get it as close as I could.
      '81 XS1100 SH
      Sep. 12th 2015
      RIP
      • #33
        Megasquirt uses a CLT (Coolant Temp) sensor to monitor engine temperature. The only real purpose of this is for enrichment during the warmup period. For air-cooled vehicles, this can prove to be a challenging feature. In Stan's build, he uses the standard GM CLT sensor and wedges it between the fins of the head for monitoring the temp of the head as this is a good alternative to actual coolant temps. With my setup, the only good place I could get this same scenario to work out was in the fins of the cylinders. I didn't like it from the start. Then, while datalogging for tuning purposes, it repeatedly fell out. This dropped the temp values which sent the bike back into warmup enrichment, which in turn caused MLV (MegaLogViewer) to filter out 90+% of my data.
        So, following on the coat tails of a guy who MS'ed his '71 911 porsche, I decided to make my own Head Temp Sensor.
        I stopped at a computer shop on my way home and picked up an old, junk power supply and upon arriving home, disassembled it.
        Here is a close up of the thermistor in place on the aluminum heatsink.
        Here is the thermistor removed next to the washer connector I mounted it in.
        I opened up the connector, split it, and carefully secured it. Appearently, thermistors are fragile, so you can't just mash it tight.
        Once it was snug, I JB Welded it in place, added connectors, and heat-shinked it. Here is the final product. Initial testing showed it was quickly responsive to the addition of mere finger temps from the application of thumb and pointer squeezed. Notice my 'special' lighter for scale. SWMBO got it for me a few years ago.
        After the assembly was complete, I needed some resistance values to calibrate it as it is different than the standard GM CLT sensor MS is set up for. The MegaTune program makes it simple. You just need 3 resistance values with corresponding temperatures. Going for the obvious and most stable, I chose to do ice water (shown below) at 33 deg F, boiling at 211 deg F, and room temp at 70 deg F.
        Tomorrow, I will mount the new sensor to the center-rear valve cover bolt. It is out of the airflow and should be a nice location for head temps.
        Hope you all enjoyed the pics and story time. I will gather some more pics during the install and share.
        '81 XS1100 SH
        Sep. 12th 2015
        RIP
        • #34
          Very nice solution to a tricky problem. Keep up the good work
          '84 Sport
          • #35
            yeah man, nice macgyvering!
            '80 SG
            '79F engine
            • #36
              is there an upper temp limit the thermistor can handle? will the head temp exceed that limit?
              '80 SG
              '79F engine
              • #37
                Really nice work,
                and hopefully a good solution to the problem.
                pete
                new owner of
                08 gen2 hayabusa
                former owner
                1981 xs1100 RH (aus) (5N5)
                zrx carbs
                18mm float height
                145 main jets
                38 pilots
                • #38
                  The sensor looks aok and you're right about them being fragile.Heat sink compound can be placed between the thermistor and what ever you are mounting it to.This allows more efficient heat transfer and keeps the contact point from becoming oxidized.Great job on your injection system. Terry
                  1980 special (Phyllis)
                  1196 10.5 to 1 kit,megacycle cams,shaved head,dynojet carb kit,ported intake and exhaust,mac 4 into 1 exhaust,drilled rotors,ss brake lines,pods,mikes xs green coils,iridium plugs,led lights,throttle lock,progressive shocks,oil cooler,ajustable cam gears,HD valve springs,Vmax tensioner mod
                  • #39
                    I think it will be okay. It handled 211 deg F just fine. The highest my sensor in the fins has gotten was 215. That was sitting in my garage syncing the TB's and running a box fan.
                    '81 XS1100 SH
                    Sep. 12th 2015
                    RIP
                    • #40
                      Originally posted by 81xsproject View Post
                      Mounting the VR sensor was one of the LONGEST ordeals. I spent ton of time looking for the 90 deg VR sensor. A 36 tooth wheel is going to be interesting. I wonder how many teeth one of the camshaft gears has...? I have seen on the MS forum where folks have used chain sprockets for their ford EDIS wheels. I thought that Stan used MS&E because the MS1 didn't support ignition without MS&E, but that Microsquirt was based on the MS2 chip which does.
                      Can you give us some more details on the VR sensor? WHich type and where you got it from?
                      I spent a while last night trying to get my Ford VR sensor fitted and it is just not going to work as it is too long..
                      The one you used looks ideal
                      Thanks.
                      '84 Sport
                      • #41
                        I spent TONS of time looking around. Everywhere around. I looked throught the suppliers book at the auto parts store for over an hour. Everytime I would find one that looked promising, it was VERY pricy. Ultimately, while perusing eBay with very general searches like "(vr,crank,position) sensor", I found this one. However, it has been so long that I don't remember for sure what it came from. It was brand new and only cost me around $30. I think that it may have come from either a newer VW or Audi. I am REALLY mad at myself for not making a note of what vehicles it was designed for. I will look through my ebay records and see if I can dig up something more specific.
                        '81 XS1100 SH
                        Sep. 12th 2015
                        RIP
                        • #42
                          I did a quick search, and found it for $25. Here is the exact one I used.
                          '81 XS1100 SH
                          Sep. 12th 2015
                          RIP
                          • #43
                            Thanks a lot. It saves buying one blind and hoping it fits!
                            '84 Sport
                            • #44
                              Is it possible to mount that sensor on the stock adjusting assembly? I read on one of these EFI threads that alignment of the trigger wheel and the sensor is tres important, so having an adjustment could make life easier?
                              '80 SG
                              '79F engine
                              • #45
                                I would say, that the clearance might prove to be something one might need to adjust. I spent a lot of time shimming to get what I thought was just the right clearance between the wheel and the sensor. The actual timing postition isn't as important. Other than during start up cranking, the base timing is totally adjustable through software. During cranking, my bike fires at TDC, because that is where I mounted my sensor relative to the wheel.
                                '81 XS1100 SH
                                Sep. 12th 2015
                                RIP
