Would you use this filter?
  • andysutt
    • Mar 2009
    • 187
    • Conway AR
    Thanks for the info on the washer, I wasn't saying it wasn't special. I was just trying to learn.
    As for the fram oil filter thing, believe what you want. Sure they all have to meet standards, but some companies decided to be better than the standard. I refuse to run fram based on the "research" that I have seen. If you want to run it, go right ahead. That's why they make different filters
    As for the Pennzoil thing, I didn't know they were bought out by another company. But your right, tear down of motors has swayed me away from Pennzoil. The people I drag race with noticed that if they used Valvoline that when they tore down the motor at the end of each race season, bearings looked better and there was less "crap" in the motor than if they used Pennzoil. A buddy also tore down his mother's motor out of a car once, It had regular 3000 miles or less oil changes, was driven as a daily driver, and was well took care of, but the inside of that motor was cruddy as all get out. It had never had anything but Pennzoil/fram combination it's whole life. Yet, a motor he tore down that used Valvoline and motorcraft filters looked alot better and had about the same mileage and use on it.
    Anyways, im not going to argue about filters, just sharing my experience and my beliefs.
    The whole thread was started to ask about a motorcycle filter and if you'd use it or not.
    '80 XS 1100 Standard
    • GaryF
      • Mar 2009
      • 54
      • South Berwick Maine
      Just picked up 2 fram filters from Advanced Auto parts for 4.69 each no waiting and no shipping charges!!
      Thanks bikerphil for the tip
      Could have gotten them in 3 days for 3.99 each from auto zone if I wanted to
      order them
      Gary
      1100SH The Chosen one
      Honda XR650L The Muddy one
        • 8893
        Yep, sometimes convienence is key.
        Washer specs in case anyone needs it..
        ID 20mm
        OD 30mm
        1mm thick
        • wa407mpp
          • Jul 2007
          • 717
          Pennzoil has Paraffin base, so it is pron to slugging if abused or if you go to long between oil changes, and because of this slugging, you don't want to use a flushing agent in an engine ran with Pennzoil, because it will wash off in large chunks and plug oil passages, and pump screens. Especially in "76 Olds. Omega's"
          Fastmover
          lion". SHL
          78 XS1100e
          • Rasputin
            • 3193
            • Lacombe, Alberta, Canada
            ID 20mm
            OD 30mm
            1mm thick
            This washer is available at your local yamaha dealer and costs about $2.50 Cdn.
            2-79 XS1100 SF
            2-78 XS1100 E Best bike Ever
              Btdt
              Andy,
              That washer is a PITA to find. When I changed my oil and filter for the first time, I found the PO had "misplaced" that washer. I went to several MC shops around my area and would have had to order one As stated, about $2.50 USD. Even specialty local hardware stores had nothing that would easily work. I got lucky and found a local Yama shops service department with some very friendly guys working there. The one guy scrounged around and found one the right OD with a little smaller ID and the right thickness that I used a dremel to open up to fit the filter bolt.
              Yes it was strictly convenience factor of not ordering one, that and the guy gave me the washer gratas.
              • andysutt
                • Mar 2009
                • 187
                • Conway AR
                Thanks for the info on the washer.
                Just curious so I asked... now I know
                • XSPastor
                  • Oct 2007
                  • 602
                  • Gaithersburg, MD
                  Oil Filter Washer
                  You can get the oil filter washer from partsnmore for a buck if you need one. If you want to make one from a regular washer, you'll probably need to Dremel out the ID a bit to get it to fit around the filter bolt.
                  Part#15-0039 at partsnmore.
                  Tim Ripley - Gaithersburg, MD
                  23mm float height
                  120 main jets
                  42.5 pilot jets
                  drilled stock airbox with K&N
                  Jardine 4 to 1 Exhaust
                  spade fusebox
                  1st and 2nd gear fix
                  • Montreux_Blue
                    XS-XJ Guru (Deceased)
                    • 1143
                    Mine was missing the washer when I did my first oil change, so I went to the Ace Hardware around the corner and found a bronze washer that fit the dimensions perfectly for about $0.75.
                    Famous Myspace quote:
                    • XSPastor
                      • Oct 2007
                      • 602
                      • Gaithersburg, MD
                      Yeah - I got a copper one in a pack of misc. copper washers from Advance auto.
                      23mm float height
                      120 main jets
                      42.5 pilot jets
                      spade fusebox
                        • 6763
                        While I have no definitive proof that Fram and Pennzoil suck...I have taken the advice to avoid them based on the experiences of others...So I would not use 'em....YMMV
                        2005 Honda SilverWing 600
                        2018 Honda PC-Xpress 150
                        • corey
                          • Mar 2005
                          • 208
                          • Dexter, MO
                          Speaking of the infamous oil filter washer/spring....
                          I haven't ran my filter with a washer since I owned the thing! I know, asking for it. Here's the kicker.... when i tore off the filter cup the first time there wasn't a washer OR a spring! I was like, WTF?!? Soooo... I grabbed a random (and might I add weak but long) spring about the right ID, stretched it out to give it more umph, and installed it without the washer. It seems to work... the oil stays clear for quite a while and the filter fills up with gunk.... It only really bothers me when I do the oil change....
                          So I guess the question is.... how important is the proper spring/washer? I know I should get one, and I plan on it. Just like I said, I forget about it. Anyone have spring recommendation? ...like where to get one?!
                          Corey J. Bennett
                          '79 XS1100SF
                            My thought is this, without the washer, the spring on mine just got shoved up in the oil filter. Without that spring pushing the filter into the right position, I doubt it actually filters the oil, the oil probably just bypasses the filter as there is a less restrictive path available. The filter is just sitting in a bowl and the path from in to out is open. JMHO
                            • andysutt
                              • Mar 2009
                              • 187
                              • Conway AR
                              I just got 5 Napa filters for $20 shipping included, not to bad.
