Fuel sending unit help
  • Axel
    • May 2007
    • 869
    • Renfrew,Ontario
    Good job
    My neighbourhood genius bike mech soldered this very thing for me and then we coated it in epoxy .
    XJ1100K
    Avon rubber
    MikesXS black coils
    Iridium plugs w/ 1k caps
    MikesXS front master
    Loud Horns (Stebel/Fiamm)
    Progressive fork springs
    CIBIE headlight reflector
    YICS Eliminator
    • XSPastor
      • Oct 2007
      • 602
      • Gaithersburg, MD
      You got it!
      Yeah!! Now get that thing together and go ride!!
      Tim Ripley - Gaithersburg, MD
      23mm float height
      120 main jets
      42.5 pilot jets
      drilled stock airbox with K&N
      Jardine 4 to 1 Exhaust
      spade fusebox
      1st and 2nd gear fix
        • 2117
        Wow-Bought the sender unit off e-bay and it arrived 2 days later.I was going to hook it up tomorrow, but figured it was going to rain so i did it today.Installed tank and started bike and took 2 minutes but the light went on.Now i can go for a ride and not have to keep opening the tank to see the fuel level.
          Just so you have a yardstick, I get about 110 miles before reserve on regular gas with my 1980 MNS. You should be able to get at least 100 miles of "normal" riding on a tank.
          • XSPastor
            • Oct 2007
            • 602
            • Gaithersburg, MD
            Yup
            I second what DiverRay said. I get exactly the same about 110 to 115 before the light comes on and then it usually takes about 3 gallons to fill it so the light comes on when you have a gallon left. You'll probably find that it will begin to cough and sputter at just about the same time so I switch to reserve when the light comes on as well and then get to a station before my 35 miles is up!
            23mm float height
            120 main jets
            42.5 pilot jets
            spade fusebox
