Rubber Boot on Drive Shaft (where to get it)
  • XSPastor
    • Oct 2007
    • 602
    • Gaithersburg, MD
    Tried that too with no results. Am I doing something wrong?
    Tim Ripley - Gaithersburg, MD
    23mm float height
    120 main jets
    42.5 pilot jets
    drilled stock airbox with K&N
    Jardine 4 to 1 Exhaust
    spade fusebox
    1st and 2nd gear fix
      Works for me
      Pastor, I was able to pull it up by part numbers.
      But I guess I ain't as cute or lucky as Eddie, they want ME to pay $43.48 for the boot and $4.32 and $5.61 for the springs.
      • XSPastor
        • Oct 2007
        • 602
        • Gaithersburg, MD
        Got it
        Hey! I got it to work. I needed to eliminate the # and the space after the part number. Duh! Still cheaper at the site I suggested though...
        23mm float height
        120 main jets
        42.5 pilot jets
        spade fusebox
        • LuckyEddie
          • 166
          • Middleville, Michigan
          Rubber Boot on Driveshaft
          I did it too by part # and got the $43.48 price also.
          I then went in the hard way and got the $29.31 price.
          Here is how to get in the hard way:
          Go to www.servicehonda.com
          Click on the "Advance OEM parts look up system"
          Scroll down the page almpst all the way and click on "Click here to begin".
          Click on "Connect"
          On the upper left ckick on "open catalog" (your cursor should tell you which one)
          Select "Yamaha"
          Select "Motorcycle"
          To the right, select "find"
          Enter "XS1100"
          Select your Year / Model
          I found the boot under "E-6" Rear arm Suspension
          Double click on the parts list to the right and the item will appear below with the price of $29.31.
          I hope this is more helpful than previous posts. I should learn to type faster some day!
          LuckyEddie
          1980 XS1100LG Midnight special
          1982 XV750J Virago
          1976 GL1000
          1978 GL1000 Supercharged
          1981 XV920RH (chain drive)
          • XSPastor
            • Oct 2007
            • 602
            • Gaithersburg, MD
            That's a great price! Weird that it's different depending on how you access it. That must mean that they somehow have two databases or they have not updated the price in all the places that it's listed. Hopefully, they'll honor the lower price. Thanks for all the work on that, LuckyEddie!
            23mm float height
            120 main jets
            42.5 pilot jets
            spade fusebox
            • snowdog51
              • 348
              • st. paul ,mn
              boot
              anyone try a plumbing mission [union] i have a swing arm off i'll check and get back.
              bill hane
              • DJinNH
                • Mar 2008
                • 854
                • New Hampshire
                Originally posted by Pat Kelly
                It was Bike Bandit
                They cost LOTS more now
                Here's the page:
                Look on the "suspension" page
                That's where I've gotten both of mine.
                Don
                currently own;
                1980 Yamaha XS1100 SG
                2009 Yamaha Star Raider
                • XJ Rob
                  • Apr 2009
                  • 161
                  • Kimball, Michigan
                  I called the 800 number for sevicehonda.com and they told me that the price is 43.48 for the boot. It is Yamaha's fault for not updating the price on the CD ROM that is sent to them every 6 months or so, and sometimes they skip over some parts listed. Mark, the sales rep. I talked to said it looked like they haven't updated that part for a couple years.
                  Rob
                  82 XJ1100
                  Stock..With a few cosmetic changes.
                  Current Project..Dad's 81 1100 Special
                  http://s727.photobucket.com/albums/ww272/RiderXJ/
                    • 7785
                    Parts source
                    I've been buying a lot of parts here:
                    Look up the part numbers you need first. Parts come in about 10 business days. I haven't been able to find a less expensive source.
