what shock are you running
  • mxmikie
    • Aug 2008
    • 482
    • Bouse az
    what rear shock are you running on the back of your xs ??????
    careful what you wish for.........you might get it
    • 7819
    I have progressive shocks on the back of my "old" bike, and S&W Air shocks on the "new" daily ride. The Midnight has the factory shocks and springs.
    • lakecountrydave
      • Aug 2007
      • 384
      • Phoenix, AZ
      I have a set of take off Hardly air shocks from one of their touring bikes. They are Showa 54565-97. I really like them
      Dave
      1979 XS1100SF Special
      • TADracer
        • May 2006
        • 1417
        • Kenner, Louisiana USA
        My 79 Special is running Prolift shocks on the rear with two stage springs.
        Mike Giroir
        79 XS-1100 Special
          • 8893
          rear shock set-up
          I have the JCW cheapo $80 shocks but with the factory XS springs on my Standard. On my Special, I have the JCW shocks with S&W 2 piece performance springs. Both set-ups work very well, after quite a bit of modification and tweaking of the pre-load.
          • ManitoulinLad
            • 358
            • Manitoulin Island,Ont.,Canada this is in Lake Huron
            This is just the question I was also wondering about. Does anybody or can you use the shocks off of Mikesxs site - they have them in the right length of 12.5" or are they not strong enough to handle the weight etc of the 1100 compared to the 650 & if not, would there gas shocks be okay - they seem to be more heavy construction. I just have the regular oem shocks on my LH & the springs are getting really rusty.
            '81 XS1100 LH - Midnight Special - been lookin' a long time for this one.
            1179 big bore kit, 80SG motor
            Rebuilt head, valves
            TC Bros Forward Controls (Brass Pegs)
            Tkat Fork Brace
            T.C. Spade Fuse Box
            Dyna Coils & wires
            Mikesxs shocks,controls,& bars (special)
            ISO grips with stelleto ends
            4 into 1 black Bassani exhaust
            Bridgestone Spitfires
            Tuned by Tinman905
            & a will to keep it.
            • randy
              • Dec 2003
              • 4521
              Progressive 402's on the back. Yamaha heavy duty in the front.
              • ManitoulinLad
                • 358
                Hey everyone - I just did a 'search' for shocks - should of done it early & found all the answers for new shocks etc that I asked earlier. Sorry to highjack the thread - I'm still new at this forum stuff. - Dan
                Tkat Fork Brace
                T.C. Spade Fuse Box
                Dyna Coils & wires
                Tuned by Tinman905
                • Korr
                  • Jul 2008
                  • 293
                  • Torrance, CA
                  Stock up front. Used to be red, but are now pink Koni's in the rear Was there when i got them & still work great!
                  1978 XS1100E Standard
                  Tkat Fork Brace
                  On Hold
                  TopCat S.O.F.A. + Fuse Block
                  Mike's XS Pod FIlters
                  • 79XS11F
                    • Jul 2006
                    • 3563
                    • Ottawa, Ont. Canada
                    On my restored bike i run stock Yamaha units front and back. On modified bike I will be installing Progressive shocks and springs.
                    Rob
                    KEEP THE RUBBER SIDE DOWN
                    1978 XS1100E Modified
                    1978 XS500E
                    1979 XS1100F Restored
                    1981 Suzuki GS1100
                    1983 Suzuki GS750S Katana
                    1983 Honda CB900 Custom
                    • aussixs11G
                      • 76
                      • Brisbane Australia
                      suspenders.....................
                      well ok.....
                      at the front I am using a fork emulator kit (FEGV S3301) and constant rate springs from www.racetech.com - using the best quality auto gearbox oil as fork oil (volume as per manual (212ml i think)
                      the emulators are great once you have adjusted them correctly for your style of riding and prevent that sickening bottoming out of the suspension in potholes or the like (we dont have roads here in Queensland just roadworks) - the performance is v similar to a modern front end.
                      at the back I'm using units from www.bitubo.com (model WME02) - these have
                      "micrometric spring preload adjustment" and rebound adjustment - I should have
                      spent the extra and bought the model with rebound adjustment but there it is.
                      the object of all this was to make the machine handle in the twisties - its no fun fanging with your mates if they leave you behind....................
                      Bryan H
                      "Conan, what's best in life?"
                      "To crush your enemies, drive them before you and the lamentation of their women"
                      • DenyP
                        • 599
                        • Staples, Minnesota 56479
                        Ok, So I am running the stock 1100E shocks and springs. I WOULD KILL FOR a smoother better ride. What is recomended? I so hate the iron butt!
                        Deny
                          • 8061
                          "I WOULD KILL FOR a smoother better ride. What is recommended?"
                          AUSSIXS11G just told you how to do it. You won't get any better advice than that. You won't have to kill, just lighten your wallet.
