carb cleaning help
  • yadada
    • 150
    • Louisburg, KS
    Sounds like you guys have it under control, so I'll help by drinking the beer that you guys have forgot to mention so far!
    Edit : Forgot it for two whole pages no less!
    Randy
    "I didn't break it! IT FAILED!"
    '82 XJ1100 "yamama"
    '09 Buell Ulysses
    '01 HD softail std - crunched
      Randy,
      It IS winter time. so I'm thinking they should be drinking a hot toddy, and NOT beer.
      The PROPER K&L kits have worked on my '79 standard, including all the emulsion tubes and needles. I second buying four complete kits, and starting with all new parts.
      • theduke
        • Dec 2008
        • 38
        • Oklahoma City
        i prefer whiskey
        40 creek, barrel select is a great choice!
        79xs11f - ugly as sin after sitting in a garage for 12 years, but rumbles like the beast that it is.
          #34
          Catatonic,
          I had no problems with mine either. See this thread
          Prom did alot of work to sort this out. I am hoping to get as lazy as him one day.
          Like you I have only done one set once and just completed over the weekend. So I have no time on my parts. I got my K&L kits (although not listed as K&L) from Georgefix on ebay for about $19 a piece. They did not include the emulsion tubes or the needles, but did have all new pilot and mains and mixture screws, float valves and seats with new screen strainers and gaskets of course.
          Duke, I would make sure and take note where your needle valves are set at before you remove the retainers to set your new ones (if you go that route) to the same setting for a beginning point.
          I am glad your jets cleaned up so nicely, I did not recognize them. I bet your float bowls look like a trash heap based upon those jets. But they should clean up also. I would make sure to pull your drains out and any rubber gaskets that go with them prior to cleaning the bowls also. Sounds like you got all of the jets and screws out alright.
