Will it fit
  • egsols
    • Jan 2006
    • 1090
    • Barrie, Ontario, Canada
    Will it fit
    Forgive my ignorance but does anyone know if an 81 valve cover will fit the 79? Me thinks it will but the part number changes in 81 from 2H7 to 4H3, the trailing numbers are the same (I know that doesn't always mean they are the same part) I always thought they were interchangeable but the different part no. has me wondering.
    Ernie
    Yup... all of them will fit. Even the XJ's will... it just says YICS on it though. I think it's just painted and un-painted is the difference... but been wrong before. All the tops of the heads are the same though with the same valve cover gaskets fitting all models.
    • XSPastor
      • Oct 2007
      • 602
      • Gaithersburg, MD
      I've got an 81 special and the valve cover says YICS on it. Weird. Either a PO changed it or they put them on before they actually instituted the YICS system.
      Tim Ripley - Gaithersburg, MD
      23mm float height
      120 main jets
      42.5 pilot jets
      drilled stock airbox with K&N
      Jardine 4 to 1 Exhaust
      spade fusebox
      1st and 2nd gear fix
      • egsols
        • Jan 2006
        • 1090
        Okay.....next question, the cover I picked up today is off a MNS. Funny, 2H7stamped inside.....any who.....can I strip the black and polish the cover up like a regular one?
        Ernie
        • petejw
          • 2269
          • sydney australia
          hey Earnie,
          U can certainly strip it back and polish it,
          get a good paint stripper, makes life a lot easier.
          pete
          new owner of
          08 gen2 hayabusa
          former owner
          1981 xs1100 RH (aus) (5N5)
          zrx carbs
          18mm float height
          145 main jets
          38 pilots
          • petejw
            • 2269
            • sydney australia
            hey Ernie,
            pete
            new owner of
            08 gen2 hayabusa
            former owner
            zrx carbs
            18mm float height
            145 main jets
            38 pilots
              Hey Pastor, sounds like possibly a PO switched yours. My 81 special does not have "YICS" on the valve cover. It is a 4RO engine.
              • XSPastor
                • Oct 2007
                • 602
                • Gaithersburg, MD
                Yeah, I think you're right. My engine is a 4RO also and matches the frame number so I know the engine is the original. I guess at some point the valve cover was damaged and replaced.
                23mm float height
                120 main jets
                42.5 pilot jets
                spade fusebox
                  Yup.. if it says YICS on it, it came off of a Maxim.
                  • egsols
                    • Jan 2006
                    • 1090
                    Thanks petejw,
                    Thanks petejw
                    Ernie
