Forgive my ignorance but does anyone know if an 81 valve cover will fit the 79? Me thinks it will but the part number changes in 81 from 2H7 to 4H3, the trailing numbers are the same (I know that doesn't always mean they are the same part) I always thought they were interchangeable but the different part no. has me wondering.
Will it fit
Yup... all of them will fit. Even the XJ's will... it just says YICS on it though. I think it's just painted and un-painted is the difference... but been wrong before. All the tops of the heads are the same though with the same valve cover gaskets fitting all models.Try your hardest to be the kind of person your dog thinks you are.
*Crashed/Totalled, still own -
I've got an 81 special and the valve cover says YICS on it. Weird. Either a PO changed it or they put them on before they actually instituted the YICS system.Tim Ripley - Gaithersburg, MD
23mm float height
120 main jets
42.5 pilot jets
drilled stock airbox with K&N
Jardine 4 to 1 Exhaust
spade fusebox
1st and 2nd gear fixComment
Okay.....next question, the cover I picked up today is off a MNS. Funny, 2H7stamped inside.....any who.....can I strip the black and polish the cover up like a regular one?Ernie
(Improving with age, the bike that is)Comment
hey Earnie,
U can certainly strip it back and polish it,
get a good paint stripper, makes life a lot easier.pete
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
[url]http://www.youtube.com/watch?v=3pA8dwxmAVA&feature=mfu_in_order&list=UL[/url]Comment
hey Ernie,
new owner of
08 gen2 hayabusa
former owner
zrx carbs
18mm float height
145 main jets
38 pilots
Hey Pastor, sounds like possibly a PO switched yours. My 81 special does not have "YICS" on the valve cover. It is a 4RO engine.Life is what happens while your planning everything else!
78 XS750Comment
Yeah, I think you're right. My engine is a 4RO also and matches the frame number so I know the engine is the original. I guess at some point the valve cover was damaged and replaced.Tim Ripley - Gaithersburg, MD
23mm float height
120 main jets
42.5 pilot jets
spade fusebox
Yup.. if it says YICS on it, it came off of a Maxim.Try your hardest to be the kind of person your dog thinks you are.
