Spark Plug poll
    • 1987
    I found this video out on the web Modifying Resistor Plug to Non Resistor Plug - DIY - YouTube. Of course the video is working with a champion plug rather then NGK. The video is what prompted my question. Why NGK chose to quit making the BP6ES is puzzling. As far as I know they are still making the cooler plug BP7ES. Anything to abandon our old bikes I suppose.
      Right, I've pulled spark plugs apart before and it's not worth it to fool with the resistors.
      Leave the plugs alone. They're, like, 5K Ohms so get rid of any resistors in the caps almost exactly the same way the guy did in the video but without the blowtorch.
      If you're still using the stock ignition coils the high voltage wires have stainless steel cores so they're effectively 0 Ohms and the resistors are in the caps.
        • 3291
        For what it's worth, that 7ES might work just fine. My ZRX 1200 has been running NGK CR10EIX, one heat range colder than CR9EIX. This CR9 in any iteration is the stock heat range. I'm running high compression pistons which was the reason for doing it.
        I don't see why an XS wouldn't work with the 7ES. I don't have an XS to try it in anymore but maybe someone would take one for the team and report back.
        2001 ZRX 1200
        1982 Seca 750
        1983 Nighthawk 550
          I've used the 7s when I was riding in the desert during the summer. It didn't make much difference.
            • 8061
            Originally posted by cajun31
            understood... my question though is there a way to remove the resistor from the old style plug caps or the BPR6ES plugs?
            I guess we switch out the resistor caps to the non-resistor type. NGK has/had non-resistor caps.
            • Geezer
              • May 2003
              • 2985
              • Willamina, Oregon 97229
              #81
              I don't remember what the number is and it's too cold to go look at the plugs in my bike but I use Bosch platinum plugs and I've been happy with them in everything I've ever put them in.
              Tony
                • 3291
                My, Platinum plugs are so 1980s... LOL. 😊
                2001 ZRX 1200
                1982 Seca 750
                1983 Nighthawk 550
                • Geezer
                  • May 2003
                  • 2985
                  #83
                  So am I for the most part...
                  Tony
                    • 3291
                    True that, Platinum plugs are all I ran in my vehicles until iridium became available.
                    2001 ZRX 1200
                    1982 Seca 750
                    1983 Nighthawk 550
