Spark Plug poll
  • Axel
    • May 2007
    • 869
    • Renfrew,Ontario
    Iridium
    Iridium for me means no choke in the summer .
    XJ1100K
    Avon rubber
    MikesXS black coils
    Iridium plugs w/ 1k caps
    MikesXS front master
    Loud Horns (Stebel/Fiamm)
    Progressive fork springs
    CIBIE headlight reflector
    YICS Eliminator
    • Dan Hodges
      Sensei of Internal Combustion
      • Sep 2004
      • 526
      • A garage in south St.Louis
      Choke or No Choke
      Is that like in choke your chicken or choke your XS? I believe .032 is the correct gap for your plugs...............in the XS but your chicken is optional.
        Dan, you must be working out again... I think you need an adjustment in the steroids!
        • Dan Hodges
          • Sep 2004
          • 526
          #34
          Da Juice
          I must admit, women like that can create a feeling of inadequacy even in a man such as myself.
          • 81xsproject
            • 3185
            • Fortuna, CA
            #35
            I used some Bosch Platinum 4+ for a while. While the make a big difference in small cars and my Toyota PU, I didn't notice anything in the XS. I will give them a second chance once I get the GM DIS system going.
            '81 XS1100 SH
            Sep. 12th 2015
            RIP
            • DenyP
              • 599
              • Staples, Minnesota 56479
              #36
              Back in the early 70's I spent too much time at the Naval base doing 25 mph with my '70 K-1 750 honda. It was a hell of a bike, but it didn't like slow, it would load the plugs up right quick. I tried several heat ranges in NGK and never seemed to solve the problem. Get the plug hot enough not to load up at 25 and would burn them up on the freeway. I switched to a new Champion plug made for bikes. Problem solved. It ran clean at low speeds and correct at hiway speeds.
              There in was my expirence with plugs and heat range. I run the standard NGK for the TimeMachine without any problems or complaints. In the summer that is, and 100 miles + per day.
              Deny
              • aussixs11G
                • 76
                • Brisbane Australia
                #37
                Plugs..............................
                I used the BP6ES units from NGK until I modded the engine - I found that the plugs were only lasting a few hundred klms (apparently higher compression kills plugs?)
                and have since used NGK Iridium BPR6EIX - these units really last thousands of klms.
                Bryan H
                "Conan, what's best in life?"
                "To crush your enemies, drive them before you and the lamentation of their women"
                • Crazcnuk
                  • 2980
                  • Hinton, AB, Canada
                  #38
                  I use NGK Iridiums as well. Just because 2 sets should outlast the bike.
                  '05 ST1300
                  • petejw
                    • 2269
                    • sydney australia
                    #39
                    I was using iridiums as well, until i replaced them
                    with standard plugs and it took away a knock i had
                    at 4-4500rpm under load.
                    its worth a try if you have a spare set of standard ngks.
                    Craz,
                    are you using the iridiums thats in the engine thats knocking?
                    pete
                    new owner of
                    08 gen2 hayabusa
                    former owner
                    1981 xs1100 RH (aus) (5N5)
                    zrx carbs
                    18mm float height
                    145 main jets
                    38 pilots
                    • Crazcnuk
                      • 2980
                      #40
                      Yes I am. I put them in last summer.
                      Easy to put the standards back in and see what it does.
                      '05 ST1300
                      • Rickrod3
                        • Jun 2009
                        • 721
                        • Oakland, New Jersey
                        #41
                        Damm I really miss my tube socks.
                        650SF
                        XS1100SG Project bike
                          I put my used spark plugs in a tube sock, you know, just in case there's a riot or stampede at Walmart.
                          • g15usmc
                            • Nov 2010
                            • 365
                            • 29 Palms CA
                            #43
                            I use the e3 spark plugs...but only after the ones i have finally quit working...I mean why buy a new one when the old ones work fine...but when i finally replace them i buy e3 they are more expensive but they have a lifetime warranty guaranteed to spark every time for life...can't really beat that...and if i've used them in something and i sell the vehicle i pull the plug put a stock ngk back in and keep my e3...never had a problem, including when used in any of the racing quads i've had over the years...that is the one thing i have replaced before necessary for racing...
                            For anyone wondering the model number is E3.34 and is a a .032 gap... and is around the $4-$6 range...
                            Daily Driver - '04 Suzuki Marauder 1600
                            Project Bike - '79 XS1100 Special
                            Hi my name is Nate and I'm am Addict...I quit riding every night before bed and can't help but start riding again the next morning...
                            Ride Till You Die!
                            "MESS WITH THE BEST DIE LIKE THE REST" -Semper Fidelis!
                            “Most motorcycle problems are caused by the nut that connects the handlebars to the saddle.”
                            "When in doubt, Gas it!. If it doesnt fix the problem, at least it will end the suspense!"
                            • James England
                              • 3039
                              • North of England
                              #44
                              Definitely a fatter, healthier spark with Iridium plugs on my bike. That and 3 ohm Dyna Coils. Huge difference. I wouldn't use a standard plug again after trying the Iridium ones.......
                              • cywelchjr
                                XS-XJ Super Guru(Deceased)
                                • 4450
                                • Sacramento, CA
                                #45
                                The iridiums do work great by all reports with aftermarket coils. However by most reports they work rather poorly with the stock coils because of their wider gap and the inability to change the gap with the brittle nature of the material preventing changing the gap causing fouling with the lowing voltage levels of the stock coils.
