Engine Removal
  • digitalsam
    • Aug 2008
    • 208
    • Carlsbad, NM
    Engine Removal
    The manual tells me to remove the mounting bolts, slide the engine forward and remove it on the right side.
    That is one honkin engine to move. Any suggestions on how to slide and remove it without rupturing discs in my back?
    Sam Christensen
    The Chronicles of my Rebuild http://xs1100rebuild.blogspot.com
    If you are leading and no one is following, maybe your just taking a walk.
    Currently bikeless. Sold my 1980 XS1100 Special
    • 8797
    If you take the upper front motor mounts out, you can slip a pipe thru the block, have a helper on the other side. Bring it out the right side.
    • Ivan
      • Jul 2008
      • 2524
      • Hutchinson KS
      I slid a couple of 1 by 4's under the engine and used them as a ramp to slide it out.
      Also, and this probably helped more than anything, I cussed A LOT.
      Ich habe dich nicht gefragt.
      • digitalsam
        • Aug 2008
        • 208
        • Carlsbad, NM
        Roar!
        Throwing all caution to the wind, I summoned superhuman strength, straddled the frame and lifted the engine forward. Then rotated it out. Thanks for the advice. Dang that was a heavy engine. I can lift the bike by hand now.
        Sam Christensen
        • thewiz
          • Oct 2006
          • 1115
          • Wilksboro, NC
          you might also ...
          find that taking the oil filter cup off will add some additional clearance ...
          80G Mini-bagger
          Past XS11s
          • thewiz
            • Oct 2006
            • 1115
            • Wilksboro, NC
            oooppsss ...
            a hair late
            80G Mini-bagger
            Past XS11s
              A 600 lb bike.. minus 225lbs for the engine.. 75 lbs worth of exhaust, seat, and tank.. Leaves a 300lb bike still. It's a magic trick!! Where is it!?
              A couple of times I've done the magic trick...
              So.. a lot lighter than it was.. yes. picking it up by hand now.. ummm.. Not if that engine seemed heavy! lol.
              • XSPastor
                • Oct 2007
                • 602
                • Gaithersburg, MD
                I love the fact that you've got this bike torn down to the point of having the engine removed and the saddlebags are still on! Nice job getting that engine out! More power to ya'!
                Tim Ripley - Gaithersburg, MD
                23mm float height
                120 main jets
                42.5 pilot jets
                drilled stock airbox with K&N
                Jardine 4 to 1 Exhaust
                spade fusebox
                1st and 2nd gear fix
                • Shappers
                  • Sep 2006
                  • 158
                  • Helsinki, Finland
                  Easy way to get it back in..
                  The downhill slope helps a lot.
                  '84 Sport
                  • subike
                    • 167
                    • Christchurch New Zealand
                    I like the way you did that with the wood.
                    When I removed mine,as I was stripping the whole bike, I just laid her on her side under my hoist, lifted the motor out with winch, shifted the frame, then slid a moving table under the engine , l owered it an started work.
                    Did the reverse putting it back in, frame lying on its left side, drop engine in .
                    no problem at all lads, none at all.
                    http://i139.photobucket.com/albums/q...e/DSC00009.jpg
                    1980 XS1100 Std English Assembled, 378k miles
                    In stock untouched contion.
                    http://i139.photobucket.com/albums/q...e/seatside.jpg
                    1979 XS1100F Std NZ new,
                    Mikes XS coils
                    Jardine 4-1
                    Pod filters
                    Harley Davidson Rear Fender
                    Bullet signal lights
                    Twin 75mm headlights
                    Self made single seat
