another carb question
  • adam79
    • 184
    • Tacoma, WA
    I am cleaning my carbs (79 XS1100SF), and have just removed the needle and seat below the float on carb #2. The reddish gasket that was under the seat is pretty much disintegrated/gone, but the same gasket on carb #1 was fully intact. Is this an indication of something, or is it normal to have dissimilar wear patterns? Can I find a single replacement gasket, or do I need a whole rebuild kit?
    • 8800
    float valve gasket
    Don't know why one would fall apart and the others are fine. Don't ya just love those PO's? Anyway, Bikebandit.com (name says it all) has 'em for $7.65 ea. or Mikesxs.com has the whole needle and seat assembly w/washer for $9.00. If your needles show any wear, I'd go for the new assemblys. JMHO
    • adam79
      • 184
      • Tacoma, WA
      Ok, thanks.
      Now, I've got all the bottoms of each carb disassembled and cleaned, except the top of the pilot jet on carb #3 is stripped and I cant get it out. What should I do?
        • 8800
        stripped pilot jet
        Yeah, that can be a bit of a dilemma. First, soak it with some good penetrating oil such as PB Blaster. Then check out this thread below. It should give you some good options.
        • oseaghdha
          • Aug 2006
          • 1075
          • N43.02.5,W88.14.2
          Originally posted by adam79
          Ok, thanks.
          I had to drill mine out. Don't remember what size drill though. It was just under the minor thread diameter. I then had to pick the threads out of the hole.
          You can try to find a left hand drill or an easy out, but I have had luck with neither one.
          XS1100SF
          XS1100F
          • adam79
            • 184
            • Tacoma, WA
            It seems other people have had a problem finding a reverse drill bit for this problem. i called the home depot and they said they didn't carry one. Does anyone know where to get one?
            • ccogswel
              • Jun 2005
              • 302
              • Bowling Green, Ky
              Snapon has them. Or use to. Matco may be anopther place to try.
              Chris
              79 XS1100 Standard aka: Mutt
              Gimme Fuel Gimme Fire!
                • 8800
                LH drill bit
                Any good tool supplier in your area should have somthing, or online link...
                http://www.mytoolstore.com/hanson/hanson.html
                • adam79
                  • 184
                  • Tacoma, WA
                  I'm looking at them now. What size should I be after? 3/16in or 1/4in?
                    • 8800
                    LH bit size
                    Whoa, those sound a bit big. I just looked at an old pilot jet I have and I think 7/64 should be the perfect size. You don't want to take any chances F'en up the threads in the carb. then you're pretty much screwed. 3/32 would be ok too.
                    • adam79
                      • 184
                      • Tacoma, WA
                      sorry, typo, I meant 3/32
                      • latexeses
                        • Jun 2008
                        • 1491
                        • California
                        Snap-on carries a set of cobalt left hand drills and screw extractors.
                        Acording to the box, part #EXDL10. I have had the set for years and wished I had had them about ten years earlier. I've never lost a screw. Yet.
                        They were a bit pricey but the cost of not having them would have been frustration to the tenth power.
                        Everything on hold...
                        • SFerinTEXAS
                          • Jun 2006
                          • 877
                          eaze out has worked for me every time. Size #1 Sears, autoparts, hardware store
                          79SF
                          XJ11
                          78E
                          • tarzan
                            • 1700
                            • Chandler,Az.
                            Sears also sells a handy extractor set with a left handed drill on one end and extractor on the other.I think the set cost me $20.Iused it to remove some screws on the rail but it didnt work for me on a pilot screw.I ended up drilling the pilot screw out to the minor dia. as stated above and using a dental pick to dig out the thread.
                            80 SG XS1100
                            14 Victory Cross Country
                            • newc4
                              • 606
                              • Vienna VA
                              My preferred method. Make sure you have a flat head screw drive that fits down the throat. Douse the jet with penetrating oil. Fire up a propane torch and heat the body around the area where the jet sets. Be sure you have off the floats, the brass ones will separate in a jiffy - don't ask how I know. Once the oil is sizzling the jets usually come out easy.
                              If you've torn up the slot, its easy out time. The same procedure works just as well.
                              Darrell
                              Darrell
                              78E
                              80G project
                              06FJR
