Hey guys! just tought I'd put up my project bike I got about a month ago. Its a 79sf and it was "modified" alot before I got it. This is how it looks right now.now I just have to De-Harelyfy it!
I just got the bike running. Thanks to EBay for the CDI! :P
It was a pain to clean them carbs. The Bike came with a Kerker 4-to-1. and pod fillters. and i think the carb is not the origonal it might be an aftermaket one or something.
the guy said these where the origonal. But half the parts are missing, so I'm using it as a parts carb(s).
I dont know if you all can tell But the carbs on the bike are diffrent. The springs are much bigger than the Parts carb(s).
And for some reason the PO changed the speedo to a 80MPH one from the specials origonal 160/180 I dont remember.
Ive got all the origonal parts for it.
he even gave me an origonal tail.
Any one what it? ill give it up for 20+shiping:P
The PO had these Harely Mufflers on with some getto arss weldding, so i just put back the origonal Kerker muffler back that he gave to me.
He also had the the side covers replaced with these ugly covers.
he gave me the origonals but he cut off the hangers for them so I've got to reweld them.
Do you guys know what I can do to Fix the cracks the origonal side covers have?
do any of you guys know what these carbs go to, the PO just gave it to me.
its the same make as ours. I think its to a honda of yamaha dirt bike.
thes is the back end of the bike.
I'm thinking of cutting of the flair on the tail and make it look like the Dyna one. What do you think.
Hope you like it. Up date soon. I need to get a regulator. Im getting one from Andreas.
The older uses pilot jet tower caps because shares it's fuel supply with MAIN jet tower via tunnel, hence larger MAINS ie. 135, vs newer carbs pilots drink directly from bowl, no caps, no sharing tunnel, and mains are smaller ie. 110-120. You jet based on carb style not just YEAR of bike/engine!
and now the bike wont idle. it will run at full choke but nothing else. Help me!
.... hey at least i am honest...
