electical woes
  • boyat68
    • Oct 2007
    • 358
    • Virginia
    Axel:
    Of course you are right, Di-electric meaning anti-electric as the dielectric constant used in capacitors arithmetic. My mind was on "No-OX" a battery connector coating that is conductive while discussing dielectric grease. My bad.
    • Axel
      • May 2007
      • 869
      • Renfrew,Ontario
      not bad at all
      Dude . I appreciate your helpful posts . No ones perfect
      XJ1100K
      Avon rubber
      MikesXS black coils
      Iridium plugs w/ 1k caps
      MikesXS front master
      Loud Horns (Stebel/Fiamm)
      Progressive fork springs
      CIBIE headlight reflector
      YICS Eliminator
      • GARTHXS
        • Nov 2007
        • 1631
        • Seattle
        so which do I need
        What do say vasaline dielectric or no ox
        91 kwaka kz1000p
        Stock
        ( Insert clever quote here )
        • boyat68
          • Oct 2007
          • 358
          • Virginia
          garthxs :
          I vote Dielectric grease as a proven corrosion barrier. I use Vaseline on gaskets to soften them and on door hinges to lubricate them, but have never used it on an electrical connection. I suppose that it would work, can't think of any bad effects.
          • GARTHXS
            • Nov 2007
            • 1631
            • Seattle
            its here!
            Just got my new wiring harness from andreas , I think I'll have to take on a final ride before I tear out the old one. I will take pics of the step by step
            91 kwaka kz1000p
            Stock
            • thewiz
              • Oct 2006
              • 1115
              • Wilksboro, NC
              routing of the harness ..
              Garth, I have the manual that shows the routing of the harness legs ... lemme know when you're gonna attempt the swap... perhaps I can get down there and give ya' a hand.
              80G Mini-bagger
              Past XS11s
              • GARTHXS
                • Nov 2007
                • 1631
                • Seattle
                first things first
                So I got the new harness and installed TC's fuse box, and then I used 3phase's new color wiring diagram and took a red sharpie and labeled all the connectors to make this as painless as possible. next thing is to clean all the connectors and use dielectric grease in all the female connections , and yes dielectric grease does promote connection so dont be messy. then do the same on my bike .
                91 kwaka kz1000p
                Stock
                • Geezer
                  • May 2003
                  • 2985
                  • Willamina, Oregon 97229
                  I would sat don't worry about being messy with dielectric grease. Take a look at how I do it in this tech tip I made on my website.
                  Geezer
                  • XSPastor
                    • Oct 2007
                    • 602
                    • Gaithersburg, MD
                    Dielectric grease is a nonconductor. Slather it wherever you want. It won't hurt anything. It is used to seal a connection not enhance conductivity. It enhances the conductivity by sealing out corrosion. It also helps to lube and seal rubber so it doesn't stick as in spark plug boots.
                    Tim Ripley - Gaithersburg, MD
                    23mm float height
                    120 main jets
                    42.5 pilot jets
                    drilled stock airbox with K&N
                    Jardine 4 to 1 Exhaust
                    spade fusebox
                    1st and 2nd gear fix
                    • GARTHXS
                      • Nov 2007
                      • 1631
                      • Seattle
                      I guess your right
                      After looking at the pics on geezers website I guess the more the better
                      91 kwaka kz1000p
                      Stock
                      • XSPastor
                        • Oct 2007
                        • 602
                        • Gaithersburg, MD
                        Hey Garth,
                        Make sure you put an extra 20A and an extra 10A in the unused sockets. It's a good idea to have spares with you...
                        Party on, Garth!
                        23mm float height
                        120 main jets
                        42.5 pilot jets
                        spade fusebox
                        • GARTHXS
                          • Nov 2007
                          • 1631
                          • Seattle
                          extra fuses
                          I was thinking of maybe a set of extra lights maybe
                          91 kwaka kz1000p
                          Stock
                            • 6751
                            So did it improve things?
                            Sounds like you did a good job.Just wondering if your electrical gremlins went away?
                            1980 XS650G Special-Two
                            1993 Honda ST1100
                            • GARTHXS
                              • Nov 2007
                              • 1631
                              • Seattle
                              not done yet
                              all i have done is label the new harness and change the fuse block , I'll probably start tomorrow on the rest
                              91 kwaka kz1000p
                              Stock
                              • GARTHXS
                                • Nov 2007
                                • 1631
                                • Seattle
                                almost done
                                Well I took out the old harness and cleaned and greased all connectors on my bike I only had to replace one connector so I could put in the 80 main switch. It looks like the right control has three wires but the plug it go's to has 5 or 6. And there seems to an extra post type connection next to the stator plug , I guess I will have to trace it down with both wiring schematics
                                91 kwaka kz1000p
                                Stock
