Hey guys,
Headlights quit (instrument lights too) and all the previous posts I read look like it's the headlight relay. So, I will pull the tank and get at it (1980 SG).
In the meantime, I checked the headlight switch to be sure the problem wasn't there, the plastic post that the hi/lo beam slide button mounts on broke. I JB welded it and it worked for a day, then broke off lower yet, right at the base of the plastic piece that has the copper spring loaded contacts that moves inside the switch cluster to change from lo to hi beam.
What's the possibility of getting any part to fix what I just described? Can I get the specific piece without getting an entire switch pod assembly bike that is just as old as mine, are there cross reference parts from other models, current models, am I screwed, etc..
Thanks in advance for any help.
