Headlight HI/LOW switch
    • 3352
    Works like a charm! Doesn't "latch" if the motor stalls to keep the light on, but otherwise the light is off until the motor fires and the headlight out indicator on the instruments glows dimly at idle and goes completely out once it revs past 1500 rpm or so.
    Not too bad!
    2001 ZRX 1200
    1982 Seca 750
    1983 Nighthawk 550
      • 2088
      Do you still have the wires jumped?
        So the question is...why don't you want to run a switch from a hot lead to make them switchable instead of doing the impulses from the alternator and the diode thing?
        Not too bad!
          • 3352
          oldyam80sg- No need to have the wires jumped now, the new relay is plug and play. It was a loose fit in the rubber mount, so I used some electrical tape to wrap it and hold it secure and put the mount back onto the tabs on the bike.
          skids- I wasn't looking to put a switch on the lights, just make the lights work as close to stock as possible w/o spending $85 on a yamaha relay that Bike Bandit shows is still available. I could have basically accomplished what you are saying by jumping the wires w/o a relay and then the lights are on when the key is on. That would be my switch if I went that route.
          2001 ZRX 1200
          1982 Seca 750
          1983 Nighthawk 550
