XJ Brake line question
  • GARTHXS
    • 1631
    • Seattle
    ooooops
    it is the midnight special im reffering to
    91 kwaka kz1000p
    Stock
    ( Insert clever quote here )
    • Jerry
      XS & TRUE XJ GURU
      • 3023
      • Elma, IA.
      The XJ front calipers use a differnt mounting dimension than any other XS11s, bolts are closer together. If you are thinking "adapter plate" then go to the Yamaha R1 - R-6 calipers instead.
      The rebuild <B>kits</B> mentioned are the same, the calipers are not.
      Jerry Fields
      '82 XJ 'Sojourn'
      '06 Concours
      My Galleries Page.
      My Blog Page.
      • Rhumba
        • 82
        • Vancouver, WA
        Wow I really opened up a can of worms here.
        By the way we were talking Master cylinders, not calipers.
        I'm pretty sure they are auto type brake line fittings but like I said to Prom, I'll disassemble it and find out for sure.
        I wonder if it's standard or metric?
        Never scratch your head with a nail gun!
        1982 XJ1100
        • randy
          • Dec 2003
          • 4521
          I dunno, dy'a think it might be metric?
          • thewiz
            • Oct 2006
            • 1115
            • Wilksboro, NC
            Sorry for heading ...
            this thread off track. Talk of the inverted flare fitting and the caliper etc prompted my unrelated question.
            80G Mini-bagger
            Past XS11s
            • jankoman
              • Sep 2008
              • 2
              • Mid-Hudson Valley, NY
              They are 3/8 inch x 24 Inverted flare fittings.
              I ordered, from DennisKirk, Russell Performance brake parts. I removed the proportioning valve and installed (1) a 3/8" x 24 inverted flare x -3 adapter (Russell R42833B), (2) A 18" straight
              -3 x -3 brake line (Russell R58213B), and (3) a 10mm x -3 Banjo 35 degree(Russell R40503B). I tightened everything up, bled it, and it works great!
              If I were to do it all over again, I would order the shorter 90 degree adapter. The long one is too long. I would use a 17" line and I would order a straight 10mm banjo instead of the 35 degree.
              As for the front, I had an extra front hose from a caliper set-up I bought on ebay [1982 XJ 1100]. So, I connected the hose to the left front caliper and ran it parallel with the right front caliper/brake hose up to the MC. Near the frame, where I removed the old (shorter) brake line for the left caliper when it was connected to the rear, is the double banjo bolt that I used for the MC. Bled both sides, and it works great too. A little sqishy, but I notice a lot more braking power from the the fronts now.
              Hope this helps anyone considering doing the same thing.
              From DennisKirk:
              Russell 10 mm (3/8 in.) Banjo x #3 Male 35 deg
              Russell Brake Line Tube-3/8 in.-24 Inverted Flare-#3 Male 90 degree Short Bend
              Russell Renegade Universal Brake Lines
