So I am going to unlink my XJ brakes and after reading almost all the posts about this I think I have a plan of action....However, I need one little piece of info.
Can someone please identify the circled connectors in the pic?
I intend to remove the P-valve entirely and run a SS line directly from the top outlet on the master cylinder to the rear brake cylinder, but I need to know what TYPE and SIZE of fitting it is. Then I just need to order the correct fitting to attach to the SS brake line.
As a last resort I will drill and tap that hole to accept a 10mmx1.25 banjo bolt (unless it already is 10mmx1.25) and just use standard banjo fittings on the SS line.
Thanks in advance.
Thanks in advance.
