still seized!
  • djcofell
    • Jun 2008
    • 13
    • Southern Ontario
    I'm not sure but I don't think so.. at least it only rounded one of the corners... bright side is there is still three solid ones to crank with... If I round another I'll regrind it to get the right amount (or more) grip without this happening again.....
    Dumped the Diesel in there today, now just gonna sit and wait a week or two on it.... Just sucks cause I don't want to work on the rest of it until I know it'll run again first....
      You'll probably get more leverage on it by sticking a board through the back wheel spokes while on the center stand and in gear and pushing and pulling on the board a bit to rock the wheel back and forth. (Easier than pushing the bike back and forth.. ) maybe try up and down instead of forward and back with the board so you don't push it off the center stand..
      I'd just try that for a bit each day... I think that would give you more oomph than using that rotor nut on the right side.... but you could try that also. Just be more persistant than it is... it'll come loose at some point.
      • olebiker
        • Aug 2007
        • 692
        • Kingston ON
        I didn't think of it before but I am assuming that you can roll the beast around in neutral. I would hate for you to be doing all this if the tranny had somehow got locked up.
        http://farm2.static.flickr.com/1241/1480921818_241eade448_s.jpg
        • djcofell
          • Jun 2008
          • 13
          • Southern Ontario
          yup, nuetral is working fine and shifting still feels the same as I remeber (little clunky into 2nd).
          • olebiker
            • Aug 2007
            • 692
            • Kingston ON
            Ok just sounds like something I might do, work like hell to get the engine loose with a locked up tranny.
            • Geezer
              • May 2003
              • 2985
              • Willamina, Oregon 97229
              Go to harbor freight and get 3 or 4 of those crappy hot air guns. With the help of a friend use all of them at once to heat the cylinders. By the time all the heat guns fail, the engine should turn over.
              Geezer
