Kinked fuel lines
  • ross
    • Dec 2006
    • 542
    • see signature...
    hey there folks...got the 2 fuel shut-off's for $9 and bought the fuel line from the auto parts store.....frugal is the rider that finds the cheaper way to fix the problem.....ross
    rebel devil
    1979 xs 1100f standard
    authenic historical vehicle
    42°36'23.52"N, 82°52'44.78"W
    "I'M IN MY HAPPY PLACE"
    "i got 14 jobs mon....you only got 1 job....you lazy bones mon"
    "if you don't wrench on it, get behind me satan!"
    '96 venture cct.....installed!
    stainless, braided, pvc coated brake lines
    i can translate...deustch, nederlands, 汉语, 漢語, français, ελληνικά, italiano, 한국어, português, русско, español and most importantly, 日本語....
    • The Lorax
      • Jun 2005
      • 1048
      • Riverside, OH
      I haven't had any significant issues with kinking fuel lines as yet, I have a special tank, no octy, capped the front ports, ran the rear to the fuel inlets. I turned my inlets so they point almost down, made a nice gradual bend up between the pods and onto the rear nipples....done, I must have gotten lucky in how I approached it as I didn't realize it was a common issue until I read this thread. have a nice day and ride safe
      I am the Lorax, I speak for the Trees
      '80 XS1100 SG (It's Evil, Wicked, Mean & Nasty)
      '79 XS1100 F R (IL Barrachino)
      '00 Suzuki Intruder 1400 (La Soccola)
      '77 KZ400s (La Putana)
      • tarzan
        • 1700
        • Chandler,Az.
        Hey lorax, it isn't much of a problem with pods,you have lots more room.However with the stock airbox its a puzzle.I tried pods when i first bought my bike, but I liked the look better with the box.But I tell ya I'm tempted to go with the pods every time I have to mess with the carbs.
        80 SG XS1100
        14 Victory Cross Country
        • egsols
          • Jan 2006
          • 1090
          • Barrie, Ontario, Canada
          Before I removed the octy and replumbed the lines I used compression springs on my lines to keep them from kinking.
          Ernie
          • The Lorax
            • Jun 2005
            • 1048
            • Riverside, OH
            The pods vs stock airbox is a different situation, my machina did not have carbs on it when I bought it, much less an airbox so I did not get the fun experience of fooling around with all that hardware. at any rate, I'm certain that there will be a good consensus as to how to prevent kinking, someone's done it, someone's designed it it must work, right? didn't know if perhaps I just came at it from a different perspective being that I had to scrounge parts and actually had to figure out how to make it run before I found this wealth of information known as xs11.com. have a nice day and ride safe
              Copper tube fuel lines?
              Hi Egleaves,
              those used to be stock up to the 1930s.
              They fit on the gas taps with threaded unions so they can be taken off with a wrench and usually had a couple of coils bent into them to take out the vibration.
                • 2117
                Egsols- That looks sharp! but what does the piece of angle due?
                • Axel
                  • May 2007
                  • 869
                  • Renfrew,Ontario
                  kinky
                  I added fuel filters recently and after a hasty sync and colortune ,I had some rough idle/running problems . Sure enuf the lines were kinky . I had replaced some with the auto thick type and the old lines couldnt handle it . I had to lengthen the lines from the octy and shorten the lines from the tee to the petcock to get the tee back over the space between the air box boots . Now it runs better .
                  XJ1100K
                  Avon rubber
                  MikesXS black coils
                  Iridium plugs w/ 1k caps
                  MikesXS front master
                  Loud Horns (Stebel/Fiamm)
                  Progressive fork springs
                  CIBIE headlight reflector
                  YICS Eliminator
                    • 2117
                    I discovered a kinked fuel line so it was taken off and i used the stock line that i got from Andreas Weiss that came off an octy.The stock fuel lines don't kink like the new thicker one.I'm waiting for fuel line from Pingel because i believe that is the best around IMO and it doesn't kink easy.
                    • egsols
                      • Jan 2006
                      • 1090
                      oldyam80sg, that's a rig I set up to check the fuel levels. I just wanted to show the springs on the lines.
                      I used the angle iron as a stand for the carbs. I just slip the carbs on it using the space between the bowls and the mounting bar. I then clamp the mounting bar to the angle iron.
                      Ernie
                        • 2117
                        I like that-Where can i get those springs?
                        • LoHo
                          • Sep 2002
                          • 1342
                          • Fresno, CA
                          Give this a try:
                          Buy some clear fuel line from a bike shop.
                          Cut it in half.
                          Hook one half to the right carb and run it out the left side. Hook the other half to the left carb and run it out the right side. There will be extra line on both sides.
                          Put the tank in position. Manipulate the line so that it has a small curve in it, enough to bend, but not so sharp as to kink. A little extra line is better than too little, and it is MUCH easier to shorten the line than to lengthen it. Hold the line next to the petcock (my wife loves that word) and eyeball or mark the place to cut the extra off. It does NOT need to be a straight line down. A little belly in the line is fine.
                          Attach the lines and ride.
                          • Axel
                            • May 2007
                            • 869
                            • Renfrew,Ontario
                            re- colortune
                            I had to re- colortune after I straightened out my fuel line problems . My settings were quite rich . Might not be related but thats what happened .
                            XJ1100K
                            Avon rubber
                            MikesXS black coils
                            YICS Eliminator
                            • olebiker
                              • Aug 2007
                              • 692
                              • Kingston ON
                              Axel if they were kinked that would starve your engine. If it was tuned to that condition it would make sense that they would have too much fuel after you unkinked them.
                              http://farm2.static.flickr.com/1241/1480921818_241eade448_s.jpg
                              • egsols
                                • Jan 2006
                                • 1090
                                oldyam80sg
                                You should be able to get those springs at any local hardware store. They are simple compression springs about 2-3 inches long. I took a piece of fuel line to the store just to make sure it fit inside the spring.
                                Ernie
