Kinked fuel lines
  • DJinNH
    • Mar 2008
    • 854
    • New Hampshire
    Kinked fuel lines
    OK, is there a trick to this? It doesn't seem to matter which way I try to adjust my fuel lines, when I put the tank on, some will kink.
    Will the aircraft stainless lines do away with this problem?
    Any suggestings or just keep trying to adjust them to fit correctly?
    Don
    currently own;
    1980 Yamaha XS1100 SG
    2009 Yamaha Star Raider
  • Pat Kelly
    • 3046
    • Golden Valley, AZ
    Longer loops of line. It's trial and error.
    That's why OEM they have springs around the fuel line.
    Pat Kelly
    <p-lkelly@sbcglobal.net>
    1978 XS1100E (The Force)
    1980 XS1100LG (The Dark Side)
    1999 Suburban (The Ship)
    1994 Dodge Spirit (Son #1)
    1968 F100 (Valentine)
    • olebiker
      • Aug 2007
      • 692
      • Kingston ON
      If you use the black line it does not kink as easy as the clear stuff. Course you can't see through it so it is a trade off.
      http://farm2.static.flickr.com/1241/1480921818_241eade448_s.jpg
      • egleaves
        • May 2007
        • 441
        • Sacramento
        I've had an idea bouncing around in my head lately about fuel lines. I have some rolls of copper tubing and the tools to bend it. I'm thinking of coming up with some custom bent fuel lines made of copper, then they would connect to the carbs and fuel tank with small lengths of rubber hose to absorb any flex or vibration. Anyone ever try this?
        I know this, because Tyler knows this.
        1980 SG
        3J6 003509
        Kerker 4-1 (sans baffles)
        Fuse Block Upgrade
        Mike's XS Green Coils
        Pods w/Homemade Velocity Stacks
        • DJinNH
          • Mar 2008
          • 854
          • New Hampshire
          Hmmm...mine are black.
          Don
          currently own;
          • zookey
            • 77
            • Minnesota
            kinking fuel lines
            My husband's bike had black lines on it when we got it. The black lines were so stiff they couldn't kink. They were also rotten and cracked. We tryed to replace them with new black line but that too kinked, so we replaced them with the clear blue and yellow fuel line. He ran blue line for the lines going to the front port of the petcock and yellow line to the back port. Made them all a bit longer so he could loop them down more so they wouldn't kink. I like the idea of either copper lines attached with rubber or maybe someone could do stainless lines.
            All in all, Yamaha didn't leave much room for play in this design. Given time and expiramenting you will find a route for the lines so they don't kink.
            1979 XS1100 Special - since 2008
            1977 XS750 Special - since 1985
            • olebiker
              • Aug 2007
              • 692
              • Kingston ON
              Oops I guess longer is the only thing left then.
                Re: Kinked fuel lines
                Don, are you running with 'crossovers' i.e. left petcock feeding right side carbs, right petcock feeding left side carbs? That was the secret for me, as it allowed a longer path with less potential for having to make a sharp bend.
                • NemisusDM
                  • Oct 2006
                  • 147
                  • Carmel, NY
                  Hello,
                  I actually had to shorten my lines to prevent kinking but, it truely is trial and error. I also used a bit of Split Loom Tubing around my Tygon lines....
                  1979 XS1100SF "Sakura Natsuhiboshi"
                  • psycoreefer
                    • Feb 2008
                    • 1557
                    • Minden, NV
                    copper....
                    most folks will tell you that copper is not good for auto/bike applications because it will fatigue and break from the constant vibrations. I think this is probably true given enough time.
                    That said I've got a remote mount oil filter on my blazer that is plumbed through a particularly tight spot with 1/2" copper tubing with sweat fittings on the ends. I've been driving it that way for just under 100,000 miles and I haven't had a problem yet, but I do check them at every oil change.
                    I like the idea of stainless = polishes up nice and shiny.
                    1979 xs1100 Special -
                    My Bike:
                    [link is broken]
                    • DJinNH
                      • Mar 2008
                      • 854
                      • New Hampshire
                      Re: Re: Kinked fuel lines
                      Ken, that may be the answer to my problem. I'll look into that.
                      Thanks,
                      Don
                      currently own;
                      • 79XS11F
                        • 3563
                        • Ottawa, Ont. Canada
                        My experience with fuel and other rubber supply lines is that the factory stuff is THIN WALLED and therefore more pliable and far less likely to kink. The stuff the bike shops and auto supply stores sell is usually not THIN WALLED and will kink pretty quick. The thicker walls just aren't as flexible.
                        Rob
                        KEEP THE RUBBER SIDE DOWN
                        1978 XS1100E Modified
                        1978 XS500E
                        1979 XS1100F Restored
                        1981 Suzuki GS1100
                        1983 Suzuki GS750S Katana
                        1983 Honda CB900 Custom
                        • tarzan
                          • 1700
                          • Chandler,Az.
                          I had that problem too when I replaced all the lines.I even used the old lines as templates,but I had to ditch those and make longer ones.
                          I ended up as has been said looping them,I actually ran two of them down between the boots and looped them there and routed them back up where I wanted them.No more kinks and I can just unbolt and lift my tank up to sync and adjust the pilot screws.I just lift the tank up and put a block of wood under it.
                          80 SG XS1100
                          14 Victory Cross Country
                          • ross
                            • Dec 2006
                            • 542
                            • see signature...
                            fuel line solution...
                            hey there DJinNH....i hope this helps....this is a picture of the left side of my bike....
                            the fuel comes outta the right side petcock...comes across the top of the air box boots....(with a fuel filter)....then dips down between carbs #1 and #2.....in this picture, the fuel flows upwards over the boot of carb #1 and into the "t" between carbs #1 and #2.....ya might have to separate the carbs and turn the "t" that supplies the fuel upwards to do this, but makes the fuel line routing very easy....better than doing that down and back up to get fuel to the carbs.....hope this helps...ross
                            rebel devil
                            1979 xs 1100f standard
                            authenic historical vehicle
                            42°36'23.52"N, 82°52'44.78"W
                            "I'M IN MY HAPPY PLACE"
                            "i got 14 jobs mon....you only got 1 job....you lazy bones mon"
                            "if you don't wrench on it, get behind me satan!"
                            '96 venture cct.....installed!
                            stainless, braided, pvc coated brake lines
                            i can translate...deustch, nederlands, 汉语, 漢語, français, ελληνικά, italiano, 한국어, português, русско, español and most importantly, 日本語....
                              • 2117
                              I got fuel line from Dennis Kirk- Moose Racing fuel line to be exact.That line is thick and does not flex well at all.I cut the lines one at a time to match my old fuel lines.No good.It kinked so i am going to go with Pingel fuel line.That stuff is very flexible even if i cant see through it!.And it doesn't kink easy.
