Aaaaaaarrrrrgggghhhhh!!!!!!!!!1
  • bobberbetty
    • Jun 2008
    • 21
    • the open road with a hot motor between my legs
    ok. if anyone can help me I would love you forever. I just put a newer motor on my 78' put the original carbs back on and to my dismay feul is leaking out of all four pod filters. to paint the picture, there is one hose running from the petcock to boot #2 and one hose running to boot #3. one hose goin from petcock to the forward connecter inbetween 2 and 3 and one goin to 3 and 4. but I cant figure out what the rear hose connectors are.
    1978 XS1100E 81' motor
    ratted out piece of lightnin. yeah.!
    • 3192
    check this thread ...see if it helps
    • bobberbetty
      • Jun 2008
      • 21
      Thats an awsome diagram but I dont have one of those octopus'
        Hey Bobber,
        Okay, the 2 vacuum hoses from the back/inside of the petcocks to the intake manifolds is to make the petcocks flow on your Standard 78E. CHECK!
        The LOWER "T" fittings on the carbs next to the float bowls are the fuel inlets! The UPPER....which I'm assuming you mean by FORWARD "T" fittings are ONLY VENTS for the bowls, and are to be connected to just hoses, "T'd" together but left to VENT!!!
        IF you have fuel lines connected to them, that's why it's flooding out!
          • 5069
          Like TC sez, you can't plug the air vent hoses!
          Hey Bobber,
          • mro
            • 4276
            • Hayward, California
            newer motor
            What year motor did you get?
            mro
            BTW, there are two ports on the front of the E's air box for the vent hoses from the carbs.
              Hi Bobberbetty,
              as I understand your post, the carbs and their fuel connections are the same as on the old engine? Did the carbs leak before you swapped in a different engine? It's all the same stuff that was there before?
              It must have been something you hooked up wrong.
              • bobberbetty
                • Jun 2008
                • 21
                ok I figured out the problem. I did have the hoses hooked up wrong. so I swapped them and it fixed the issue.
                thanks for all your help guys.
