i have been thinking about my XJ that i have sitting in the shop and how the XJ's have the YICS and those ports that run between each cylinder and how there happend to be the holes convenantly there....
some have talked about putting nitrous nozzles there, but i have thught about port fuel injection with a tunable ECU and turbo setup.would only need the intake manifolds for boosted air....
1979 XS1100 SF "Black Goblin"
-Pod Filters
-4-1 pipe
-larger jets for carbs
1982 XJ1100 "Black Sheep"
It wouldn't be difficult to make an 1-4 intake manifold for a single carb/throttle body. I still haven't welded up my Vegas Tank fuel pump port either....ok nighty nite....
MDRNF
79F.....Not Stock
Manifold would be relatively easy to make. Just 4 tubes attaching to a mixing chamber with the carb flange welded in the middle. You may have to baffle the intake to equalize air/fuel ratio to each cyl, but that isn't mind boggling.
