So my buddy pulls up on a (new) VTX 1300, sounds good, looks generic, and runs great....anyways got to studying his intake and saw 1 (one) carb running the powerful 1300cc motor...Got me thinking that only one carb to adjust on my beast would be pure sin. Looked it up on Google, IIRC,I think it is a 36mm CV....So question is, would this carb run our 4 cylinder bikes correctly? With the proper intake manifold of course?
Alternative (CARB)
hey chop,
you could, theyve being doing that to cars for years. :-)
but i dont think it would b worth the hassle, the making and designing of the manifold, then getting a carb jetted and set up.
spend a cpl hundred on some kliens
you'll never look back. :-)
petepete
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
[url]http://www.youtube.com/watch?v=3pA8dwxmAVA&feature=mfu_in_order&list=UL[/url]Comment
Not sure how it would work but it would be good on gas.
Score one of those 40 mm keihin carbs from a Harley, off Ebay, for about 75 bucks. They have an exccelerator pump on them and are very tuneable. Or score an S&S Super E and fit that one= very- very tuneable and much more responsive, but more money.Last edited by GNEPIG; 06-26-2008, 09:11 PM.Comment
XSCHOP,
why run a 2 barrel carb when you can have a 4 barrel......? pure more power incentive.....thats why you run the bigger mm carb. if you were going to put a single carb on, it sure would be alot eaiser to TURBO...hehehe or if you wanted to get really easy tune run a throtle body injection, mass air flow senser, a ECU and then you can program the thing....with a TURBO....
these thoughts have ran through my mind.....hehe
1979 XS1100 SF "Black Goblin"
-Pod Filters
-4-1 pipe
-larger jets for carbs
1982 XJ1100 "Black Sheep"Comment
hehehe, yeah!!!
but turbos are free power could maybe run a pully for SC off of the pick up coil side, or create an extension off of clutch basket with a seal.......hmmmmm........
-Pod Filters
-4-1 pipe
yeah, you would have to wait on your speed to pick up before gaining power....... normally you run it off a pully on the crank for the insant power........ so in our case i belive turbo is a better canidate.
I saw a bike once with a SC i dont remember what it was but i remember think, geeez do you even need that?
now i know the awnser......
YES!!!1979 XS1100 SF "Black Goblin"
-Pod Filters
-4-1 pipe
i am thinking of boost off of the line.......more launch power....1979 XS1100 SF "Black Goblin"
-Pod Filters
-4-1 pipe
