I'm getting ready to order stainless steel brake lines for my '78 Std and I have a question regarding the rear brake line. There is a rubber brake line running from the master cylinder (maybe 6") which then connects with a fitting to a thin metal tube, then another maybe 6" rubber brake line connecting to the caliper. When replacing with stainless steel brake lines, do you replace both rubber lines and keep the metal tube in between? Or do you replace the whole thing with one stainless steel line? Probably a dumb question.....
Replacing rear brake line
I've wondered that myself so I'll be listening too...Tim Ripley - Gaithersburg, MD
23mm float height
120 main jets
42.5 pilot jets
drilled stock airbox with K&N
Jardine 4 to 1 Exhaust
spade fusebox
1st and 2nd gear fix
Can do it both ways, I believe the peference is to run just one ss line from mc to caliper. It's bound to be cheaper.
If running one line just route it so it can't come in contact with the rear tire.Ernie
