Replacing rear brake line
  • Chuckster
    • 93
    • Crystal Lake, IL
    I'm getting ready to order stainless steel brake lines for my '78 Std and I have a question regarding the rear brake line. There is a rubber brake line running from the master cylinder (maybe 6") which then connects with a fitting to a thin metal tube, then another maybe 6" rubber brake line connecting to the caliper. When replacing with stainless steel brake lines, do you replace both rubber lines and keep the metal tube in between? Or do you replace the whole thing with one stainless steel line? Probably a dumb question.....
    Chuckster
    '78 XS1100E
    Money can't buy happiness, but it can get you an XS11 and that's a start.
  • XSPastor
    • Oct 2007
    • 602
    • Gaithersburg, MD
    I've wondered that myself so I'll be listening too...
    Tim Ripley - Gaithersburg, MD
    23mm float height
    120 main jets
    42.5 pilot jets
    drilled stock airbox with K&N
    Jardine 4 to 1 Exhaust
    spade fusebox
    1st and 2nd gear fix
    • egsols
      • Jan 2006
      • 1090
      • Barrie, Ontario, Canada
      Can do it both ways, I believe the peference is to run just one ss line from mc to caliper. It's bound to be cheaper.
      If running one line just route it so it can't come in contact with the rear tire.
      Ernie
      • D. P. Larmee
        • May 2003
        • 224
        • Evanston, IL
        All the sets that I have used replaced the three piece rear line with one stainless line.
        1980 XS 1100 Standard
        1980 XS 1100 Special
        1982 XJ 1100
        1972 Honda CB 350
          I replaced mine with a single run of braided stainless. No sense introducing any more joints and potential leak points.
          YMMV
          • TADracer
            • 1417
            • Kenner, Louisiana USA
            Straight line from MC to caliper does the trick.
            Mike Giroir
            79 XS-1100 Special
            • DJinNH
              • Mar 2008
              • 854
              • New Hampshire
              Question...what was the length of SS line needed for that? I have an 1100SG and SH but I am guessing the lengths are about the same for other bikes.
              Don
              currently own;
              1980 Yamaha XS1100 SG
              2009 Yamaha Star Raider
