It's alive! muhahaha
    Take a little extra care on the rotor install. I had just set it on a the crank shaft a couple times and installed it. Apparently there was some sort of dirt or something somewhere because it made the rotor rub the stator. Any rubbing at all will ruin them, and they aren't cheap or always easy to find. The shaft is slightly cone shaped and the rotor is also to fit it. Spray the shaft and rotor down liberally with carb cleaner. Get a block of wood on the face of the rotor and give it a good whack with a shop hammer to get it set good on the crank, then torque the bolt.
    There is very little clearance between the rotor and stator on the cover of the XJ's when it's installed. I've ruined 2 stators by not doing it this way.... and none since I have.
    • stereomind
      • 109
      • Tulsa, OK
      Thanks for the advice, guys. I'll make sure the rotor is on 100%. I'll crank the motor over by hand after the install to make sure there's no binding.
      '81 XS1100SH "Hound of Basketville" - new project
      '81 XS1100H Venturer
      '81 XJ750RH Seca
      • 79XS11F
        • 3563
        • Ottawa, Ont. Canada
        Originally posted by XSPastor
        dbeardslee,
        Tha galley plug is on the ignition side of the engine. He's talking about the alternator side.
        There's a plug on each side. On the timing side it is a alloy bolt and on the alt side it is a simple plug. that's the way it is set up on the XS11 engine anyway ..
        Rob
        KEEP THE RUBBER SIDE DOWN
        1978 XS1100E Modified
        1978 XS500E
        1979 XS1100F Restored
        1981 Suzuki GS1100
        1983 Suzuki GS750S Katana
        1983 Honda CB900 Custom
        • XSPastor
          • Oct 2007
          • 602
          • Gaithersburg, MD
          If you ain't makin' mistakes you just ain't tryin' and I appreciate your efforts on various threads. Probably just God keepin' you humble. I understand he likes his Pastors that way
          Doug
          Aint that the truth!!
          Tim Ripley - Gaithersburg, MD
          23mm float height
          120 main jets
          42.5 pilot jets
          drilled stock airbox with K&N
          Jardine 4 to 1 Exhaust
          spade fusebox
          1st and 2nd gear fix
          • stereomind
            • 109
            • Tulsa, OK
            there is no bolt...
            Just realized something... The PO omitted the flywheel bolt! UGH.
            Any clue as to what size that bolt was?..
            thanks!
            Vlad
            '81 XJ750RH Seca
              bolt
              Not sure of the size, but Bikebandit.com has them for $3.50 ea.
              • stereomind
                • 109
                • Tulsa, OK
                you guys rock
                Yay! Flywheel came off, thanks to a loaner puller bolt... Just screwed it in tight, and whomped it with a hammer real good... The old seal put up a fight at first, but on-demand-OCD always wins
                New seal is in, and no more leak.. I applied some 1104 gasket sealant around the perimeter before I stabbed it back in. I also found a suitable replacement bolt and washer in the junk drawer, and cut out a new gasket for the alternator cover.
                From the looks of it, there's no chance of that bolt backing out since the way the motor turns, it would constantly try to tighten, right?
                Thanks guys, I appreciate all the advice!
                Vlad
                '81 XJ750RH Seca
