wont start
  • AustinPhoenix
    • Mar 2008
    • 112
    • Austin, TX
    Righto
    Oh yeah...I forgot the fan.
    I think you would want to rejet BEFORE going through all of that work. Otherwise you'd be doing it for nothing.
    1980 XS11g Standard - "Ash"
    4 to 2 Exhaust
    K&N Pod Filters
    Fuel Filters
    Inline shut off valves
    Slotted Rotors
    My heart and soul
    Soon to have stainless lines, xs750 FD, lightened rotors, and HID headlight
    1979 Special Project Bike
    Non-gasoline conversion
      So pre sync with bread tie or some other small width thing
      Once you do the "bread tie, you WILL have to turn the idle down.
      And then check fuel mix then vacuum sync then fuel mix again, and possibly rejet and. All of the former again?
      Yes, and if you look from the MAIN PAGE, in the "Tech Tips" there is a tip on doing the sync, as well as setting the idle mixture screws. It does take a while at first, but it will get faster. The last time I did mine, it took one hour flat from parked to riding.
      DO NOT FORGET A FAN!!
      • GARTHXS
        • 1631
        • Seattle
        sync
        so did I mention me exhaust is a high flow 4/1 bassini do you thhink my jetting is correct 142.5 main. I have some pilot jets , a set of 42.5, 47.5 and 50 I looked in the tech tips and it says 45 is stock pilot for a 78e it seems to idle rough and then creep up and rev up to 4-5k is it sync or just mix, like I said in prior post I vacuum synced last week so how does the different jet affect sync, also do I have to adjust the needles
        91 kwaka kz1000p
        Stock
        ( Insert clever quote here )
          Garth
          The manual says 42.5 is the correct pilot jet for a 78E.
          • planedick
            • Mar 2005
            • 2068
            • Yorba Linda, California
            Always
            It is always necessary to synch again after taking the carbs off or making any changes to the mix or jets. There is really no way to get around a vacuum synch. If you skip it your bike will probably run crappy.
            Drilled airbox
            Tkat fork brace
            Hardly mufflers
            late model carbs
            Newer style fuses
            Oil pressure guage
            Custom security system
            Stainless braid brake lines
            • GARTHXS
              • 1631
              • Seattle
              thanks
              I guess I'm going to pull my carbs and check the float needle clip and float heights and then do the pre sync, I don't have a vacuum sync anybody in sandiego who has one, please help me out??
              91 kwaka kz1000p
              Stock
