gas coming out of carb
  • tarzan
    • 1700
    • Chandler,Az.
    I didnt see which year and model you have but on my 80 SG if the o-ring that is under the needle seat is bad it can cause flooding.I havent had it happen to me but have seen guys on here say they have.
    80 SG XS1100
    14 Victory Cross Country
    • tiredoffixing
      • Mar 2008
      • 89
      • Ohio
      SH
      Its an 81 sh I am going to try a new float and float valve. I hope this works cause I jusy got it runing good
        Hey Tired,
        Don't go ordering a new float until you check your old one, the plastic ones rarely go bad!!! Like Tarzan said, the 81 uses the O-ring under the float needle seat, and these can shrink, causing leaks, so with a new float needle, get the seat/O-ring. You might even be able to find a neoprene O-ring at your local hardware store that would fit!
        I had rebuilt mine some 8 years ago, and they started leaking a little this year, replaced the float needles and they are good again!
        • tiredoffixing
          • Mar 2008
          • 89
          • Ohio
          THANKS
          thanks for the info. I will give that a try. What number are the float valves on mikesxs? Thanks again
            • 8963
            needle + seat
            Push-in type with o-ring, needle + clip, p/n 48-1445 at mikesxs.com.
            • tiredoffixing
              • Mar 2008
              • 89
              • Ohio
              Thanks I will give that a try
