hello, i have a left turn signal that wont work, i changed the bulb still noting, now the warning light for the turn signal will not go out. the light lights up when it is just normally running. please help as i need to certify
right turn signal
lights
how hard to change all my lights to led. i hear this saves power and since i cant get the current one to work probably would be a good idea. do i need anything other than the lights.....and conversion kits or anythingSteve Josch
Toronto ontario
1982 xj1100 maxim owner -
You will still need to get the wiring sorted out to run LEDs. They do use a lot less power, but you still need to have clean, reliable connections or nothing's ever going to work reliably. Have a browse through some of the technical articles about electrical gremlins to see what you might be up against.Ken TalbotComment
Cowboy - mine are picky about how the wires are connected. There's a negative and a positive that need to be in the correct places. Switch 'em around and they don't work right. Sure you got all your +'s and -'s in the right holes?I think I have a loose screw behind the handlebars.
