right turn signal
+ More Options
Posts
  • cowboy5
    • 60
    • toronto, ontario
    right turn signal
    hello, i have a left turn signal that wont work, i changed the bulb still noting, now the warning light for the turn signal will not go out. the light lights up when it is just normally running. please help as i need to certify
    Steve Josch
    Toronto ontario
    1982 xj1100 maxim owner
  • cowboy5
    • 60
    • toronto, ontario
    lights
    how hard to change all my lights to led. i hear this saves power and since i cant get the current one to work probably would be a good idea. do i need anything other than the lights.....and conversion kits or anything
    Steve Josch
    Toronto ontario
      You will still need to get the wiring sorted out to run LEDs. They do use a lot less power, but you still need to have clean, reliable connections or nothing's ever going to work reliably. Have a browse through some of the technical articles about electrical gremlins to see what you might be up against.
      • BrianB
        • 362
        • Idaho
        I would suspect it is a grounding issue.
        1980 XS Eleven Special
        • dbeardslee
          • 4385
          • Maineville, OH
          Cowboy - mine are picky about how the wires are connected. There's a negative and a positive that need to be in the correct places. Switch 'em around and they don't work right. Sure you got all your +'s and -'s in the right holes?
