hello, i have a left turn signal that wont work, i changed the bulb still noting, now the warning light for the turn signal will not go out. the light lights up when it is just normally running. please help as i need to certify
right turn signal
lights
how hard to change all my lights to led. i hear this saves power and since i cant get the current one to work probably would be a good idea. do i need anything other than the lights.....and conversion kits or anythingSteve Josch
Toronto ontario
1982 xj1100 maxim owner
You will still need to get the wiring sorted out to run LEDs. They do use a lot less power, but you still need to have clean, reliable connections or nothing's ever going to work reliably. Have a browse through some of the technical articles about electrical gremlins to see what you might be up against.Ken Talbot
Cowboy - mine are picky about how the wires are connected. There's a negative and a positive that need to be in the correct places. Switch 'em around and they don't work right. Sure you got all your +'s and -'s in the right holes?I think I have a loose screw behind the handlebars.
