"Hard to say what went on there, Fred."
Tires, sitting unmounted... the bead area tends to curl inward.
What I mean is the tire tends to curl and close up.
So, you've got a rim that 4 inches wide, and you're trying to mount a tire that's collapsed to maybe a two inch opening.
Yes, you can seat the bottom side... but how does one get the tire to expand so that the upper side moves up that 2 inches so the bead area hits the rim?
That's the fun part.
Starting fluid?
Tighten a cargo strap around the tread to squeeze the tire open?
Use an inner tube?
I believe it was GNEPIG, years ago, stated, "Inflate an inner tube inside the tire, place the tire out in the sun for a few hours. It will soften and sometimes revert back to it's normal shape. Take it back inside and try to remount it.
Starting fluid?
Use an inner tube?
