Rear Needle bearing discontinued!!!
  • mrfiznix
    • Aug 2007
    • 24
    • CA
    Zanotti and Bike Bandit have both told me that the part #93313-62010-00 is discontinued. I am stuck! I read in the forum that this is a YAMAHA only part, but now it is gone forever? I checked the Yamaha website and the whole rear wheel assembly has no parts listed. Did anyone have luck finding a replacement?
  • xschop
    • Feb 2006
    • 1794
    • oklahoma city
    ID
    Is the ID 20mm. If so, then don't worry. take it out, mic it then call a bearing/transmission shop. They will find one (WAY CHEAPER THAN YAMAHA TOO!)
    MDRNF
    79F.....Not Stock
      • 7831
      You SHOULD be able to find TWO bearings that will fit together in the space of the single bearing. As xschop said, mic the old bearing, and then call a bearing supply. You CAN get them, as I looked about three years ago. My problem was the Yamaha bearing was LESS MONEY than two bearings with a spacer.
        So what size is it?
        Hi Fiznix,
        What is the bore, OD & length of this bearing? If it is for sure an unobtanium special bearing, get the nearest size of commercial bearing (one with the same OD & a larger bore is best but it depends on what you can find in the catalogs) and press a sleeve over it or into it or whatever it takes to make it fit.
        • mrfiznix
          • Aug 2007
          • 24
          • CA
          this one, the expensive one.
          • xschop
            • Feb 2006
            • 1794
            • oklahoma city
            number on bearing?
            MDRNF
            79F.....Not Stock
            • mrfiznix
              • Aug 2007
              • 24
              • CA
              Bearing # is
              INA-NTN o2
              NA 5904 V1
              • randy
                • Dec 2003
                • 4521
                Those numbers won't mean anything to a bearing shop, that bearing was made special by Koyo only for Yamaha, so your best bet would be as previously written, to mic it and try to match two side by side?
                • mrfiznix
                  • Aug 2007
                  • 24
                  • CA
                  I called yamaha, they told me to pound sand. I called the manufacturer, INA and they told me if it was made exclusively for yamaha and to contact them. I will try some bearing shops to try to match up, though I wish I had the exact part to replace. Thanks everyone for responding so fast and with so many responses. Keeping another 1100 on the road!
                  • xschop
                    • Feb 2006
                    • 1794
                    • oklahoma city
                    here ye
                    MDRNF
                    79F.....Not Stock
                    • egsols
                      • Jan 2006
                      • 1090
                      • Barrie, Ontario, Canada
                      Hey xschop,
                      I punched up 93313-62010-00 in my search engine and it took me right to the link you posted!!!!!
                      Most searches for anything xsive leads back to the cornucopia of xsiveness!
                      Ernie
                      • xschop
                        • Feb 2006
                        • 1794
                        • oklahoma city
                        20x37
                        the bearing in your hand is 20x37x????? if need be I could spin out a spacer and make another width bearing drop in....
                        MDRNF
                        79F.....Not Stock
                        • xschop
                          • Feb 2006
                          • 1794
                          • oklahoma city
                          here's a solution
                          Buy premium ball bearings online from VXB.com - your trusted bearing supplier and distributor. Explore a wide selection of bearings at wholesale prices with same-day shipping and next-day delivery. Precision, speed, and reliability delivered fast.
                          make a 5mm spacer and you are set....
                          MDRNF
                          79F.....Not Stock
                          • mrfiznix
                            • Aug 2007
                            • 24
                            • CA
                            yes, 20 ID by 37 OD by 23 mm thick
                            • 81xsproject
                              • 3185
                              • Fortuna, CA
                              Also, check out All Balls Racing. They had listed a rear wheel bearing and seal kit for a 79 xs11. It was $13, but listed that it came with 1 bearing and 2 seals. So, maybe not. It might be worth calling them though with the specs and telling them about out issue.
                              '81 XS1100 SH
                              Sep. 12th 2015
                              RIP
