Rear Needle bearing discontinued!!!
  • prometheus578
    XS-XJ Super Guru (RESIGNED)
    • Aug 2004
    • 4012
    • Olympia , Wa.
    "The mighty Casey has struck out."
    Stopped at Yamaha to check the rumors.
    Still in the parts fiche.. but whoops, none in the warehouse. Discontinued.
    Told 'em to order me one anyway.... see what happens... if it arrives next week.
    Price was now forty something bucks...
    I had bought three last year for $33.
    Don't even think about it... I hoard.
    (Yes, TRBIG... it sounds the same, but the meaning is different)
    • 79XS11F
      • 3563
      • Ottawa, Ont. Canada
      When I ordered a set of stock handlebars for my restored bike it took a while to get them because they came from Japan but they did arrive in time. That bearing "may" still be available from the manufacture because they "may" have found another use for it across any given number of machines they make bearings for.
      It will be interesting to see if the one you ordered arrives.
      Rob
      KEEP THE RUBBER SIDE DOWN
      1978 XS1100E Modified
      1978 XS500E
      1979 XS1100F Restored
      1981 Suzuki GS1100
      1983 Suzuki GS750S Katana
      1983 Honda CB900 Custom
      • rman
        • 228
        • Stroudsbug PA
        source
        Another possable source for the needle bearing.
        Trying not to offend since Aug 28, 2010
        Disclaimer: I am an idiot. Pay no attention to the man behind the curtain.
        Owner of:
        1979 XS1100F (The Pig)
        140 mains
        45 pilot jets
        Floats at 24mm
        Running Rich
        "Arrogant, delusional tyrants can't be stopped by earnest words and furrowed brows. Action, strong bold action coming from a position of strength and determination, is the only effective deterrent." -Mitt Romney
          So that's what 'unobtainuim' looks like
          rman, it looks like you have stumbled onto something. At that price. It would behoove us to buy a spare for each bike in our stable.
            • 3373
            Anyone tried out that bearing from WBDS listed in the post above?
            Anyone checked into it? I sent an email and am waiting to hopefully hear back.
            2001 ZRX 1200
            1982 Seca 750
            1983 Nighthawk 550
            • randy
              • Dec 2003
              • 4521
              Think about this. Mention has been made about using this bearing with a spacer. You will need TWO spacers, one for the center on the axle and one for the outside dimension of the bearing.
              I suppose these spacers could be made from the carcass of the old bearing?
              • prometheus578
                • Aug 2004
                • 4012
                • Olympia , Wa.
                "I've lost my bearing."
                What concerns me about that bearing, at least from the pic... It's not a sealed bearing...
                Plus, theres no inner "sleeve"/collar?
                Looks more like a bearing that needs to be surrounded, or bathed in the lubricant... not one that sort of stands alone on an axle.
                Odd... haven't had a phone call from Yamama concerning my order.
                Might need to stop in there and see what the deal is.
                Sadly... I'm forced to leave the house today... need to go to the part's store. Blew an axle grease seal on the truck.
                (No big deal... rear brakes haven't worked for years... but now there's this growing oil stain on the driveway.)
                Glad it's cloudy out... bright sunshine makes trips outside more miserable for me. (Hard for me to hide in the shadows, and all.)
                  On the palm of his hand
                  Hi Prom,
                  the bearing shown on mrfiznix' hand is a Drawn Cup Roller Bearing. The outer case (the drawn cup) relies on being pressed into a cylindrical housing to keep it's shape under load. The rollers run on a hardened & ground sleeve that the Mfr also sells or directly onto a hardened & ground shaft. Torrington and INA are the big names in this style of bearing. As the Yamaha bearing seems to be no longer available and is apparently a non-standard size, a search of Mfrs catalogs to find the nearest best fit amongst the stock bearing sizes is the best way to go. Then go to "Bro with lathe" to get whatever size of sleeve or spacer that's needed to make up the difference.
                  • prometheus578
                    • Aug 2004
                    • 4012
                    • Olympia , Wa.
                    Thanks, Fred.
                    • Paintman
                      • Mar 2008
                      • 312
                      • rapid City SD
                      who lost thier bearings
                      I have a very large bearing distributor 6 miles from my place i can pull one and go play the match game if i get lucky il post the price and availability on here.
                      john
                      79 XS1100SF 750 FD,Galfer Brake lines,ebc brake pads,Cross Drilled Rotors,TKat fork brace,bead blasted wheels repainted and polished
                      80 XS1100 S Project gonna be a hot rod
                      06 CBR1000RR sold!!!!!
                      2000 Concours
                      84 Kawi KLR600
                      79 Yam XT500 Ouch it kicks back
                      79 XR250
                      Why is it that the smallest part can fly to the farthest part of the shop?
                      John
                        • 3373
                        This bearing looks to be the correct size, not the one that takes two smaller bearings and a spacer.
                        Those thoughts about it being an open bearing, etc are good ones.
                        paintman, you are the man if you can find a match. I can't pull mine to take in for comparison, out of fear I'll ruin it like I did the right side bearing. Just cleaning and re packing it while on the wheel will suffice for me, it is in great shape.
                        2001 ZRX 1200
                        1982 Seca 750
                        1983 Nighthawk 550
                        • prometheus578
                          • Aug 2004
                          • 4012
                          • Olympia , Wa.
                          "I was sadly misshapen."
                          Somehow, had another bearing in mind.
                          Have a whole drawer of used bearings that I used to press new ones in with.
                          Big honking bearing... thought that was the one in question.
                          Just got back from Yamaha... no luck there.
                          Even got on the phone with the "All Balls" people.
                          Got confusing.
                          They had a Yamaha bearing kit...they said wheel... for about $37.30, so things looked promising(based on the price). Then... the specs were all wrong.
                          As for my earlier post... disregard what I wrote, as most of you do, anyway.
                          Yeah, Fred, you're right.
                          I found my spare bearing... has a removeable inner sleeve, etc.
                          I had forgotten what these things looked like.
                          That link that Mrfiznix posted looks like the deal. Same measurements, etc.
                          Ok, who's gonna buy one and test?
                            • 3373
                            Yes, who's going to give it a try? Preferably someone who has no other option, things seem to work best that way! My bearing is still in good shape and re-packed in the wheel, so I am NOT TOUCHING IT!
                            2001 ZRX 1200
                            1982 Seca 750
                            1983 Nighthawk 550
                            • mrfiznix
                              • Aug 2007
                              • 24
                              • CA
                              strange
                              http://www.wbds.com/htm/NKIA5904-SKF.htm
                              I ordered from wbds.com and got it today, but it is slightly different. There is 3/4 of it needle bearing and 1/4 ball bearing. Any problems foreseeable like this? Oh, the bearing in my earlier post in my hand had the inner race taken out, I just left it out to see the inner needle bearings easier. The bearing in this picture has the inner race, I took it out for a couple pix and put it in for one. At wbds.com they said the bearing I ordered wasn't in stock, but they could ship a INA branded one. I said great! because I thought it would match up exactly with the old one that was an INA branded 5904
                              • randy
                                • Dec 2003
                                • 4521
                                mrfiznix;
                                The I.D. of the inner sleeve is 20mm?
