Changing handlebars and the MC
  • wapam
    • Dec 2007
    • 39
    The MC base is angled to remain level on the buckhorn handlebars. Would changing to a flatter bar mess up the MC as it would not sit level on "flatter" bars.
    Hope that made sense.
    Thanks.
    • 7819
    That is correct. It "should" still work, but may be harder to fill. The second option would be buy a "new" unit, designed for the normal bars.
    • Dsxs11
      • Jun 2007
      • 240
      • Millington, Michigan
      Mine works fine on drag bars. and it's sits pretty flat. I do have to turn the bars to the left to fill it.
      I hate signatures. Too many cars and Bikes to list here.
      • 81xsproject
        • 3185
        • Fortuna, CA
        Mine worked fine on super bike bars (before I changed it out).
        '81 XS1100 SH
        Sep. 12th 2015
        RIP
          • 8894
          mc
          I have CB750 bars on my 79SF and the master sits at an angle but still works fine. I just turn the bars all the way to the left while on sidestand to remove cap and fill. That levels it out. You shouldn't have a problem. HTH>
          • TADracer
            • May 2006
            • 1417
            • Kenner, Louisiana USA
            Mine works fine on my 2 1/2" rise bars. To fill or blead I turn the bars to the left and loosen the bolts a bit to rotate the MC to a relatively flat position. Simpe.
            Mike Giroir
            79 XS-1100 Special
