Changing handlebars and the MC
  • wapam
    • Dec 2007
    • 39
    The MC base is angled to remain level on the buckhorn handlebars. Would changing to a flatter bar mess up the MC as it would not sit level on "flatter" bars.
    Hope that made sense.
    Thanks.
    That is correct. It "should" still work, but may be harder to fill. The second option would be buy a "new" unit, designed for the normal bars.
    • Dsxs11
      • Jun 2007
      • 240
      • Millington, Michigan
      Mine works fine on drag bars. and it's sits pretty flat. I do have to turn the bars to the left to fill it.
      I hate signatures. Too many cars and Bikes to list here.
      • 81xsproject
        • 3185
        • Fortuna, CA
        Mine worked fine on super bike bars (before I changed it out).
        '81 XS1100 SH
        Sep. 12th 2015
        RIP
          mc
          I have CB750 bars on my 79SF and the master sits at an angle but still works fine. I just turn the bars all the way to the left while on sidestand to remove cap and fill. That levels it out. You shouldn't have a problem. HTH>
          • TADracer
            • 1417
            • Kenner, Louisiana USA
            Mine works fine on my 2 1/2" rise bars. To fill or blead I turn the bars to the left and loosen the bolts a bit to rotate the MC to a relatively flat position. Simpe.
            Mike Giroir
            79 XS-1100 Special
