Brake adjustment
  • conky1980
    • 19
    • Creston South, Newfoundland, Canada
    Brake adjustment
    I have a sticky rear brake on my 82 xj11 and I was wondering if there is a way to adjust it? The brake pedal sticks down. Thanks again.
    1982 XJ1100
  • maxedout
    • 11
    • Ohio
    I just had similar problem, tried couple adjustments but eventually found that the spring just needed good shot of pb blast to loosen things up.
    • mro
      • 4276
      • Hayward, California
      If the pedal is "sticking" remove it and clean the shaft, little grease and re-install. There is some adjustment on the rear master cylinder but has nothing to do with a sticky pedal.
      What condition are your calipers/MC/proportioning valve in ?
      mro
      • conky1980
        • 19
        Hey mro, I got the shaft out and got it based in anti-seize compound, but when I tapped the shaft out the big spring that puts your foot pedal back to the ''off " position popped off and I can't figure out how it goes back on. Please help, thanks again.
        1982 XJ1100
        • mitch
          • Oct 2002
          • 934
          Check this out
          Try looking at this
          Doug
          Doug Mitchell
          82 XJ1100 sold
          2007 Stratoliner 1900 sold
          • mitch
            • Oct 2002
            • 934
            Sry wrong page
            Enter your year make Brakes etc and you will get an exsploded view of your break pedal
            Doug
            Doug Mitchell
            82 XJ1100 sold
            • conky1980
              • 19
              Hey Mitch, the link you sent helped me big time. It has lots of useful diagrams. Thanks again.
              1982 XJ1100
