Steering Head bearing removal
  • jkorn
    • May 2003
    • 188
    • Wickenburg AZ
    OK so my 30 year tune up is getting out of hand. I am trying to get ready for my bikes 30 year birthday. Its born on date is 4/78.
    While checking the steering head I can see that that the bottom bearing race this is set in the stem is banged up. Wonder how I did that. Any way I want to install a new bearing set but can not get the old bearing off of the lower yoke assembly. It seems to be pressed on.
    Has anyone found a easy way to get that bearing off.
    Jeff Korn
    Original Owner 79XS1100 E
  • John
    • 5117
    Check out this thread. You will be able to do it this way if you have the proper tools.
      • 8931
      bearing splitter
      An easy way to remove that bearing is with one of these....
      It must be a small one to fit in between the steering travel stops.
      • prometheus578
        XS-XJ Super Guru (RESIGNED)
        • Aug 2004
        • 4012
        • Olympia , Wa.
        "And what thread is that, John?"
        Jeff....
        Die grinder and a cutting wheel. Cut a slice or two and then have at it with a chisel. (After breaking off the cage and removing the rollers)
        Some times I've been lucky... Can get a chisel under the bearing and work it up and loose that way.
        • jkorn
          • May 2003
          • 188
          • Wickenburg AZ
          thank-you, thank-you
          Jeff Korn
          • jwoell
            • 63
            • Wichita, KS
            If you are still looking for some info you can check out this thread...
            I know this only because I went through the exact same thing last fall
            '81 XS11 SH (XSelsior)
            • John
              • 5117
              Re: "And what thread is that, John?"
              Originally posted by prometheus578
              Jeff....
              Sniff, sniff...what's that smell? Brains?
