Steering Head bearing removal
  • jkorn
    • May 2003
    • 188
    • Wickenburg AZ
    OK so my 30 year tune up is getting out of hand. I am trying to get ready for my bikes 30 year birthday. Its born on date is 4/78.
    While checking the steering head I can see that that the bottom bearing race this is set in the stem is banged up. Wonder how I did that. Any way I want to install a new bearing set but can not get the old bearing off of the lower yoke assembly. It seems to be pressed on.
    Has anyone found a easy way to get that bearing off.
    Jeff Korn
    Original Owner 79XS1100 E
    Check out this thread. You will be able to do it this way if you have the proper tools.
      bearing splitter
      An easy way to remove that bearing is with one of these....
      It must be a small one to fit in between the steering travel stops.
      • prometheus578
        XS-XJ Super Guru (RESIGNED)
        • Aug 2004
        • 4012
        • Olympia , Wa.
        "And what thread is that, John?"
        Jeff....
        Die grinder and a cutting wheel. Cut a slice or two and then have at it with a chisel. (After breaking off the cage and removing the rollers)
        Some times I've been lucky... Can get a chisel under the bearing and work it up and loose that way.
        • jkorn
          • May 2003
          • 188
          • Wickenburg AZ
          thank-you, thank-you
          Jeff Korn
          • jwoell
            • 63
            • Wichita, KS
            If you are still looking for some info you can check out this thread...
            I know this only because I went through the exact same thing last fall
            '81 XS11 SH (XSelsior)
              Re: "And what thread is that, John?"
              Originally posted by prometheus578
              Jeff....
              Sniff, sniff...what's that smell? Brains?
