rear drive problems
    • 7765
    Jerry, I don't think it's that hard of a job. We pull the coupling on the 750 FD to seal the oil hole, and then reinstall it. Takes about 5 minutes.
      The coupling will come right out, and you can take the pinion gear out of the hub, but you may new to change the shims on the new hub as it may have slightly different tolerances.
      • Jerry
        XS & TRUE XJ GURU
        • 3023
        • Elma, IA.
        Thanks. I'll try pulling the coupling some time to get beter photos of the splines.
        Has anyone tried swapping the guts of a 750 / 850 final drive into the 11 housing? Would be more trouble than the accepted method of swapping in a 750 / 850 FD; just curious if it could be done.
        Jerry Fields
        '82 XJ 'Sojourn'
        '06 Concours
        My Galleries Page.
        My Blog Page.
        • xschop
          • Feb 2006
          • 1794
          • oklahoma city
          swapping
          won't work, and also the drive pinions won't swap/match either....
          MDRNF
          79F.....Not Stock
          • scappod
            • Mar 2005
            • 233
            • Bremerton Washington
            drive shaft
            Here ya go brew.
            I have tried to post pics for ya since 2 days ago so lets try it here
            [IMG]http:i137.pphotobucket.com/albums/q220/scappod/dscf0013.jpg[/IMG]
            Lets see if that works
            Ego Sum Meus Frater Custodis...
