trans headache
  • tinman905
    • Aug 2007
    • 946
    • Orangeville,Ontario ,Canada
    If you still need a set of gears I might be able to help you there.
    BDF Special
    • clint
      • Oct 2007
      • 26
      • ohio
      are they back cut??
      • tinman905
        • Aug 2007
        • 946
        I have no idea I just bought them and still waiting for delivery. I just picked them up to have an extra set .
        BDF Special
        • clint
          • Oct 2007
          • 26
          • ohio
          #34
          tinman did you just win them on sunday on ebay for like 21.00 or close to it??
          • tinman905
            • Aug 2007
            • 946
            #35
            yes that's the set.
            BDF Special
            • clint
              • Oct 2007
              • 26
              • ohio
              #36
              i will keep you in mind if i need a gear thanks
              • randy
                • Dec 2003
                • 4521
                #37
                Sorry, Yes, madmax-im, I was referrring to your setup and your problem. Many have found the stock carbs to work with your setup using only minor changes.
                • clint
                  • Oct 2007
                  • 26
                  • ohio
                  #38
                  i dont know where to get carbs but all this talk makes me want to get some hehe tranny fix is going good gears are at the machinist as we speek should have them back in few days then back on the bike then i am installing a 2005 kawasaki636 front end so thats the next project then i will think about carbs
                  • AlanB
                    • Oct 2006
                    • 705
                    • Scotland
                    #39
                    Hi Clint,
                    Probably a good fork, but is it long enough?
                    I am a fan of more modern parts on XSs CLICK HERE! But most modern front-ends lower the bike too much; Even my antique FZR fork gives clearance problems over kerbs, although the improvements in braking and handling make it all worthwhile!
                    The wheel has been replaced with an 18" since the write-up.
                    AlanB
                    If it ain't broke, modify it!
