Slingshot carbs
  • 81xsproject
    • 3185
    • Fortuna, CA
    Slingshot carbs
    I know there has been a lot of discussion about these carbs particularly trying to ID them. Well if anyone wants to try a set HERE are some on ebay. AlanB will gladly give you his jetting data as well.
    '81 XS1100 SH
    Sep. 12th 2015
    RIP
  • GNEPIG
    • Apr 2005
    • 1657
    • fl
    I like the idea, but where do you plug in the vacuum advance?
    And how much jetting mods are required, as this set has the after market kit in it?
    • AlanB
      • Oct 2006
      • 705
      • Scotland
      Hi GNEPIG,
      You can either put a restrictor in the line and plug the Vac advance into the nipple on the boot, or leave it blanked.
      I have run both, equally successfully. According to the Dyno, Power was no different. Vac advance is "off" at WOT! Economy (and possibly smoothness?) are better on a long run with the Vac advance.
      These carbs were recommended to me by the local Dynojet agent, and was set-up and tuned on their Dynojet dyno.
      They recommended NOT fitting a jet kit for this application.
      AlanB WONT willingly give his jetting data......... not 'cos he is a cheap s#n of a b!tch, but 'cos it won't particularly help anyone with a non-identical exhaust and set-up!
      I will tell you that settings from one vehicle will not necessarily transfer to another, and will offer any useful help I can. Mine are very close to the stock Suzuki settings, and actually ran pretty well before I altered them at all.
      AlanB
      If it ain't broke, modify it!
      • pggg
        • 1609
        • NZ
        If piped and freeflow filter/filters I'd try 130 - 140 range on main jets and likely up a size at least on the pilot jets and/or up a notch on the slide needles and idle screws tweaked to match, also with a drilled airbox taping over or untaping the holes for more fine tuning
        • 81xsproject
          • 3185
          • Fortuna, CA
          Sorry 'bout that, Alan...
          '81 XS1100 SH
          Sep. 12th 2015
          RIP
          • AlanB
            • Oct 2006
            • 705
            • Scotland
            Hi Guys,
            The dyno shop who did the tuning for my slingshots fitted lots of these carbs to CV equipped '80s bikes; mainly Zthous/elevens and the GSX11s. They had full Dynojet facilities, including a complete range of pilot jets and needles.
            They stated that they had almost never wanted to change either pilots or needles for this type of conversion.
            Most bikes wanted Mains sorting out, Needle POSITION altered, and pilot screws ADJUSTED........ no new parts except mains!
            Pggg is pretty close with his jetting; I have K&Ns and a free-flowing 4-1.... Mains are middle 140s. Needle position and pilots will depend on your own set-up.
            There carbs are very easy to set, compared to the XS originals; MUCH more forgiving!
            Go for it!... It will be the best mod you have done to your XS....EVER!
            AlanB
            • petejw
              • 2269
              • sydney australia
              Go for it '81,
              thats not a bad price 4 them either.
              im still trying to find a set,
              not havin much luck tho,
              will keep tryin.
              pete
              new owner of
              08 gen2 hayabusa
              former owner
              1981 xs1100 RH (aus) (5N5)
              zrx carbs
              18mm float height
              145 main jets
              38 pilots
              • 81xsproject
                • 3185
                • Fortuna, CA
                No, YOU go for it . SWMBO has put the smack down on parts buying for a while. You are right, however, that is a good price.
                '81 XS1100 SH
                Sep. 12th 2015
                RIP
                • 81xsproject
                  • 3185
                  • Fortuna, CA
                  yep, such a good deal they are already gone.
                  '81 XS1100 SH
                  Sep. 12th 2015
                  RIP
                  • 79XS11F
                    • 3563
                    • Ottawa, Ont. Canada
                    You can't leave stuff like that laying around for long .. eh. They will be a good addition and final engine related part that I need for my hop up bike once color tuned and Dial-A-Jetted :-)
                    Rob
                    KEEP THE RUBBER SIDE DOWN
                    1978 XS1100E Modified
                    1978 XS500E
                    1979 XS1100F Restored
                    1981 Suzuki GS1100
                    1983 Suzuki GS750S Katana
                    1983 Honda CB900 Custom
                    • Guy_b_g
                      • May 2007
                      • 790
                      • Beverly Hills, Florida
                      AlanB,
                      I have a set of these carbs also...and have a fairly free flowing 4 into 1 exhaust. The jetting info is appreciated.
                      Question, what are you using for pod filters? The mounting lip for the filter on these carbs is pretty narrow, and has no grooves to help keep the pods from sliding off, plus they are somehat oval/egg shaped.
                      Any help on pod options / sources and pod mounting tips would be very welcome.
                      Thanks,
                      Guy
                      Guy
                      '78E
                      • AlanB
                        • Oct 2006
                        • 705
                        • Scotland
                        Hi Guy,
                        I have the recommended two-into-one K&N filters for the Slingshot.
                        There are some pics HERE!(CLICK!)
                        I have posted that link so often that I get embarassed now...........
                        AlanB
                        • 81xsproject
                          • 3185
                          • Fortuna, CA
                          For those interested. I did some research on the subject and the slingshots were available in the US (whether they were called that, I don't know). They did come in a few different jetting varieties; UK, US, and US California). The other variety is that like Alan's carbs some have the rubber tube on the back side. This is basically a high RPM enricher which is essentually useless if you aren't turning over 10k rpm. For those that want the years and specs, they can be found HERE on the Gixxer.com forum.
                          '81 XS1100 SH
                          Sep. 12th 2015
                          RIP
                          • pggg
                            • 1609
                            • NZ
                            Hey 81' 10000 revs ain't a problem, about the spacing, Ive got set of 38mm, but haven't run them, they're spaced wide as, even wider than an elephant XS1100 motor, tricked carb boots are the story there, the 38mm's are probably way over the top, top end power only with a mach111 type power band and bare open pipes and mosquito netting for filters needed for any sort of response, they wouldn't be that bad, also there's keihin cvk 36mm, look similar to slingshot carbs inside the throats, they're classy turbine-like fuel delivery, you'd better hang on, idle to redline, barely touch the throttle and the bikes hammering towards the horizon like there's no tomorrow, you gotta upgrade the handling too, no kidding
                            • 81xsproject
                              • 3185
                              • Fortuna, CA
                              Looks like there are about 3 sets of these carbs on the bay right know.
                              Here
                              Here
                              http://cgi.ebay.com/SUZUKI-GSXR-1100...QQcmdZViewItem
                              '81 XS1100 SH
                              Sep. 12th 2015
                              RIP
