Right side exhaust is backfiring, and blows a light colored smoke when I get on it. Also smokes after I shut the bike off. Just took the carbs off and re-cleaned, set float levels to proper specs, and bread tie syched. Didnt happen until I did this. Also, #3 exhaust pipes sizzle when I spray water on them whereas #1 do not. Any ideas?
Smoke and backfire
Looks like #1 is not firing every time and the unburnt fuel ignites in the pipes when it does = your backfire. If your 100% sure that the carbs are good then check ignition system with the focus being on #1. Could be as simple as a bad plug.
RobKEEP THE RUBBER SIDE DOWN
1978 XS1100E Modified
1978 XS500E
1979 XS1100F Restored
1981 Suzuki GS1100
1983 Suzuki GS750S Katana
1983 Honda CB900 Custom
Forgive the error above...dont know what happened. Number 1 and number 2 pipes both DO NOT burn the water off when I spray them down. Numbers 3 and 4 sizzle and the water turns to steam immediately. It only smokes and backfires from the right side exhaust....numbers 3 and 4. I also broke a float post in both 3 and 4 when setting float levels. Fixed with magnasteel. May be part of it?80XS11G (heavily modified) "Snot Rokkit"
Deuces Wild
Custom Paint & Body
1200 N. Wall Sreet
Calhoun, GA 30701
770-608-3779
That's going to be carbs or fuel supply to carb ... because ignition is not paired 1&2 , 3&4. So start at the fuel tank and work your way down. If fuel supply is good then it's likely off with the carbs .. again.
1978 XS500E
1981 Suzuki GS1100
Yay.They are probably screwed since the float posts were broken. I was able to set float levels correctly but I was worried about them since I broke them. I dont have the extra funds for another set of carbs anytime soon if they are to far gone.
Deuces Wild
Custom Paint & Body
1200 N. Wall Sreet
Calhoun, GA 30701
770-608-3779
those posts can be repaired if you have the pieces. contact cleaner and JB wield.
1978 XS500E
1981 Suzuki GS1100
Well I figured out that the #2 carb wasnt getting any fuel into the float bowl because the float valve is screwed. I love waiting 2 weeks for a $10 part that keeps me off the road.80XS11G (heavily modified) "Snot Rokkit"
Deuces Wild
Custom Paint & Body
1200 N. Wall Sreet
Calhoun, GA 30701
770-608-3779
