Smoke and backfire
  • roach25681
    • Jun 2007
    • 69
    • Calhoun GA
    Smoke and backfire
    Right side exhaust is backfiring, and blows a light colored smoke when I get on it. Also smokes after I shut the bike off. Just took the carbs off and re-cleaned, set float levels to proper specs, and bread tie syched. Didnt happen until I did this. Also, #3&#4 exhaust pipes sizzle when I spray water on them whereas #1&#2 do not. Any ideas?
    80XS11G (heavily modified) "Snot Rokkit"
    Deuces Wild
    Custom Paint & Body
    1200 N. Wall Sreet
    Calhoun, GA 30701
    770-608-3779
  • 79XS11F
    • 3563
    • Ottawa, Ont. Canada
    Looks like #1 is not firing every time and the unburnt fuel ignites in the pipes when it does = your backfire. If your 100% sure that the carbs are good then check ignition system with the focus being on #1. Could be as simple as a bad plug.
    Rob
    KEEP THE RUBBER SIDE DOWN
    1978 XS1100E Modified
    1978 XS500E
    1979 XS1100F Restored
    1981 Suzuki GS1100
    1983 Suzuki GS750S Katana
    1983 Honda CB900 Custom
    • roach25681
      • Jun 2007
      • 69
      • Calhoun GA
      Forgive the error above...dont know what happened. Number 1 and number 2 pipes both DO NOT burn the water off when I spray them down. Numbers 3 and 4 sizzle and the water turns to steam immediately. It only smokes and backfires from the right side exhaust....numbers 3 and 4. I also broke a float post in both 3 and 4 when setting float levels. Fixed with magnasteel. May be part of it?
      Deuces Wild
      Custom Paint & Body
      1200 N. Wall Sreet
      Calhoun, GA 30701
      770-608-3779
      • 79XS11F
        • 3563
        That's going to be carbs or fuel supply to carb ... because ignition is not paired 1&2 , 3&4. So start at the fuel tank and work your way down. If fuel supply is good then it's likely off with the carbs .. again.
        Rob
        1978 XS500E
        1981 Suzuki GS1100
        • roach25681
          • Jun 2007
          • 69
          • Calhoun GA
          Yay. They are probably screwed since the float posts were broken. I was able to set float levels correctly but I was worried about them since I broke them. I dont have the extra funds for another set of carbs anytime soon if they are to far gone.
          Deuces Wild
          Custom Paint & Body
          1200 N. Wall Sreet
          Calhoun, GA 30701
          770-608-3779
          • 79XS11F
            • 3563
            those posts can be repaired if you have the pieces. contact cleaner and JB wield.
            Rob
            1978 XS500E
            1981 Suzuki GS1100
            • roach25681
              • Jun 2007
              • 69
              • Calhoun GA
              Well I already fixed them with MagnaSteel....but I didnt have the original broken pieces. Just Magnasteeled the pins to the broken side.
              Deuces Wild
              Custom Paint & Body
              1200 N. Wall Sreet
              Calhoun, GA 30701
              770-608-3779
              • roach25681
                • Jun 2007
                • 69
                • Calhoun GA
                Well I figured out that the #2 carb wasnt getting any fuel into the float bowl because the float valve is screwed. I love waiting 2 weeks for a $10 part that keeps me off the road.
                Deuces Wild
                Custom Paint & Body
                1200 N. Wall Sreet
                Calhoun, GA 30701
                770-608-3779
