finished mine
This bad boy puts the inside sprocket 86 mm from the case exactly with 15mm left/wider adjustment....will install it on the the stock frame (PEPE, formally known as Blue-Streak) tonight, run a string and check clearance....The housing is bulletproof and the bearing races are machined better than factory according to my machinist friend. we zeroed both the Factory M/D housings from front to back and they are not consistent....Looks like Mr. Miyagi was hittin' the Saki at the Yamaha M/D factory back in the day. The first pic shows the exact mirror image of the housing/Locator Dowel pin hole and engine case Boss/ bearing race dimentions. last picture shows the stock shaft ready for the sprocket.....last thing I will do is lighten it up (haven't decided to mill the front or back)and add the xs11 insignia.....
..... P.S. will order the sprocket today. I installed the housing and it fits like a glove.......
For anyone thinking of rigging Chops unit to their XS, the main advantage is you can gear your bike to your own preference and your back tyre needn't look so wimpy compared to the modern bikes. Also you get a weight loss and the bike accelerates a bit quicker, but the power increase isn't massive although there's some extra kick allright. Riding/cruising, you can't tell any difference between the shaftdrive or chaindrive, thats with a cushdrive rear wheel, very smooth, not sure what a solid rear setup would be like, but doubt there'd be much difference. With Chops unit bolted in, the hardest part would be rigging a rear wheel/swingarm/brake setup
