carb holders ?
  • mro
    • 4276
    • Hayward, California
    but gas brakes it down
    So...your carbs leak?
    Have had black electrial tape on my 80G for a least a year and is still there. Start it under the clamp, wind it forward then back to under the clamp. Think that may be why it's still there
    mro
    • brownbear1000
      • May 2007
      • 83
      • Bay View wisconsin
      tap
      I used it on my boots and it lasted one day and it crack and it whood not let the thing idol down kep it at 3 grandhad to shut the bike down allmost hit someone
        yes it works great on elc. stuff but not with Gas
        This self vulcanizing tape that we were talking about... I used to use it to wrap wires that stayed in fuel all the time inside fuel pods. This isn't normal electrical tape.
        • timeless-cowboy
          • May 2007
          • 25
          • akron ohio
          carb holders
          ok gus if fi understan this right ...if there are cracks that are vacume leeks the bike will run real bad but is that from the start or after about 3-4 miles running?
          1980 xs1100
          1981 xs 400
          1982 verago 750
            • 5069
            Re: carb holders
            If they leak,m you will have a tough time maintaining a steady idle and synching the carbs is also a not-so-funny affair! You will be resetting synch after you fix the boot leak.
            • pggg
              • 1609
              • NZ
              I'm doubtful all these carb boots are leaking thru surface cracks, the boots are 10mm thick and bonded to alloy manifolds inside the rubber, all these air-leak problems are likely coming from the carb/boot join or the boot/cylinder head join
