Help
  • Axel
    • May 2007
    • 869
    • Renfrew,Ontario
    still at it
    Well hours later and no go . I checked and cleaned connections and inspected vac lines and fuel lines. Is there a continuity test I can do to test the pickup coil circuit cuz it looks ok ( i'm sure that doesnt mean much ) . I tested resistor caps and across the coil (spark plug wires ) . Can the coils have a bad ground ?
    XJ1100K
    Avon rubber
    MikesXS black coils
    Iridium plugs w/ 1k caps
    MikesXS front master
    Loud Horns (Stebel/Fiamm)
    Progressive fork springs
    CIBIE headlight reflector
    YICS Eliminator
    • Axel
      • May 2007
      • 869
      • Renfrew,Ontario
      Randy's TCI page
      Wow ,thats a great site ,even a movie . There's a easy test to figure out where to go troubleshooting that even I cant screw up.
      THANKS RAY
      XJ1100K
      Avon rubber
      MikesXS black coils
      YICS Eliminator
      • Axel
        • May 2007
        • 869
        • Renfrew,Ontario
        and on it goes
        Can you believe I cant find 3/16 vac line in this one horse town ?
        No fuel line other than the thick stuff either . Oh well , no one said it was going to be easy...
        http://home.ptd.net/~theragos/xs11/tci%20faq's.htm
        I will do the TCI test tomorrow, check fuses, test coils , try to test the pickups and every connection I can find
        XJ1100K
        Avon rubber
        MikesXS black coils
        YICS Eliminator
        • mro
          • 4276
          • Hayward, California
          Check at a shop that does work on mowers/chain saws etc..
          mro
          • Dragon Tamer
            XStremely XSive(Deceased)
            • Sep 2006
            • 426
            • Half way between Chili and Winter Wisconsin.
            Axel,
            The pickup coils should test out a 600 to 800 ohms, the main coils should test out at 1 to 2 ohms on the primary side and about **15,000** ohms on the secondary. Sounds likely that you have a pickup coil out.
            **corrected secondary value**
            The Old Tamer
            _________________________
            1979 XS1100SF (The Fire Dragon)
            1982 650 Maxim (The Little Dragon)
            another '82 650 Maxim (Parts Dragon)
            1981 XS1100SH (The Black Dragon)
            If there are more than three bolts holding it on there, it is most likely a very important part!
              • 5069
              Not including tha plug caps, I thought it should be more like 15,000 ohms (15K) on the high volt side.
              Originally posted by Dragon Tamer
              the main coils should test out at 1 to 2 ohms on the primary side and about 1500 ohms on the secondary.
              • Axel
                • May 2007
                • 869
                • Renfrew,Ontario
                No spark 2&3
                I keep hearing this spark arc happening it the battery region . I thought it might be the TCI but after I removed the cover ,I think not . Fuses are good but I will clean the holders
                XJ1100K
                Avon rubber
                MikesXS black coils
                YICS Eliminator
                • Axel
                  • May 2007
                  • 869
                  • Renfrew,Ontario
                  TCI time
                  Tested at the TCI . Seems to point to pickups but they test equally at 125ohms TCI time ? or hammer time ?
                  XJ1100K
                  Avon rubber
                  MikesXS black coils
                  YICS Eliminator
                  • Axel
                    • May 2007
                    • 869
                    • Renfrew,Ontario
                    anybody out there ?
                    Re-tested everything . Still no further ahead
                    XJ1100K
                    Avon rubber
                    MikesXS black coils
                    YICS Eliminator
                    • Axel
                      • May 2007
                      • 869
                      • Renfrew,Ontario
                      act 3
                      It started to work for a second so I put it all back together and ...you guessed it : it stopped working .I'm now resoldering the TCI .
                      XJ1100K
                      Avon rubber
                      MikesXS black coils
                      YICS Eliminator
                      • Dragon Tamer
                        • Sep 2006
                        • 426
                        Hey Skids,
                        Thanks for catching that, it was what I intended to say but my 'puter must be missing a zero on the keyboard or something!
                        The Old Tamer
                        • Axel
                          • May 2007
                          • 869
                          • Renfrew,Ontario
                          no luck
                          No luck since I re-soldered the TCI . Whats left but to start again ?
                          XJ1100K
                          Avon rubber
                          MikesXS black coils
                          YICS Eliminator
                            • 5069
                            Re: no luck
                            If you can hear spark, it must be the coil wire or cap jumping to ground!
                            • Axel
                              • May 2007
                              • 869
                              • Renfrew,Ontario
                              false alarm
                              Turned out be to a false alarm . It was a relay near the battery .
                              XJ1100K
                              Avon rubber
                              MikesXS black coils
                              YICS Eliminator
                              • Axel
                                • May 2007
                                • 869
                                • Renfrew,Ontario
                                Still no spark on 2&3 .
                                XJ1100K
                                Avon rubber
                                MikesXS black coils
                                YICS Eliminator
