clutch job
  • mason79
    • Mar 2006
    • 1351
    • los angeles, ca
    you are right mro.
    thanks for the initial offer, i do have extra
    History
    85 Yamaha FJ 1100
    79 yamaha xs1100f
    03 honda cbr 600 f4
    91 yamaha fzr 600
    84 yamaha fj 1100
    82 yamaha seca 750
    87 yamaha fazer
    86 yamaha maxim x
    82 yamaha vision
    78 yamaha rd 400
      Hey Mason,
      I was just reviewing the old tech tips, and found one about the Barnett clutches, just that he said that they are not flat!?
      This could be possibly due to the aluminum base of the frictions, but I remember my OEM frictions were very lightweight, so I think they are also aluminum instead of steel, so not sure why this person(many years ago) experienced warped plates???
      As for the dimples, perhaps Barnett didn't put any on there to increase total contact/friction area between the plates. The frictions should still be slotted, so oil should still be able to flow between them. But perhaps this is also why they are reported to be stickier, less likely to separate due to strong fluid adhesion!?
      Good luck and be careful putting the starplate backin!
      • mason79
        • Mar 2006
        • 1351
        • los angeles, ca
        [/URL]
        i haven't taken it apart yet, but it appears that the friction's slots are shallower than in your picture's tc,
        i checked everything on a flat piece of glass, and they seem flat.
        History
        85 Yamaha FJ 1100
        79 yamaha xs1100f
        03 honda cbr 600 f4
        91 yamaha fzr 600
        84 yamaha fj 1100
        82 yamaha seca 750
        87 yamaha fazer
        86 yamaha maxim x
        82 yamaha vision
        78 yamaha rd 400
        • mason79
          • Mar 2006
          • 1351
          • los angeles, ca
          #34
          how do you get the clutch cover off? it's stuck, i tried a rubber mallet, sticking the soft handle of a screwdriver in the oil fill hole,
          help!
          History
          85 Yamaha FJ 1100
          79 yamaha xs1100f
          03 honda cbr 600 f4
          91 yamaha fzr 600
          84 yamaha fj 1100
          82 yamaha seca 750
          87 yamaha fazer
          86 yamaha maxim x
          82 yamaha vision
          78 yamaha rd 400
            Double and triple check that all the screws are out, but you're on the right track. Sometimes these are just really stuck. The last one I had that was like this, I doubled up some strong twine, ran it through the clutch cable hole and tied the twine into a loop. Then I used a hammer handle through the loop to tug on.. it finally popped off.
            • mason79
              • Mar 2006
              • 1351
              • los angeles, ca
              #36
              thanks got it off with the mallet, now the kick starter came loose, how to put it back?
              History
              85 Yamaha FJ 1100
              79 yamaha xs1100f
              03 honda cbr 600 f4
              91 yamaha fzr 600
              84 yamaha fj 1100
              82 yamaha seca 750
              87 yamaha fazer
              86 yamaha maxim x
              82 yamaha vision
              78 yamaha rd 400
                This isn't going to give you the complete picture since this motor only has the kickstarter shaft, not the other gears involved, but the shaft and spring go here....
                Like so....
                  OOPS... hit send twice apparently! Hope this helps.
                  • mason79
                    • Mar 2006
                    • 1351
                    • los angeles, ca
                    #39
                    done, now to test it, thanks trbig!
                    History
                    85 Yamaha FJ 1100
                    79 yamaha xs1100f
                    03 honda cbr 600 f4
                    91 yamaha fzr 600
                    84 yamaha fj 1100
                    82 yamaha seca 750
                    87 yamaha fazer
                    86 yamaha maxim x
                    82 yamaha vision
                    78 yamaha rd 400
