i know i know i should read the tech tips, blah, blah, blah.
i did, i need help.
my clutch is slippin more and more must be my great tune job,
and the added weight of fairings and trunk and junk in the trunks.
i want to go into it once and in one day, i don't mind buying parts i don't need to replace, than to open her up and take measurments to find out i need parts and hafta wait a week or more to get them, making a 1 day job into a 2 week job.
i read about the washers
i read about tc's xtra plate
i read about maximans breakin the star plate, hope that don't happen.
bottom line
when i buy new springs, should they be heavy duty, or can stock rates do the trick?
can i go with oem type friction plates rather than barnett brand?
and for good measure will i need to add a steel plate even tho i did the above?
what are the chances of the steelplates being bad? the po took great care with this bike...
i ain't gonna make my own gasket, i think the material out there is kinda thick, won't that negate the effect of an additional plate?
best place to buy this stuff?
please again thanks in advance for your expert input guys and gal.
i did, i need help.
bottom line
As previously stated, teh star plate is what is displaced by the extra steel, and the center clutch throwout push rod is what is adjusted to compensate for it, so gasket thickness doesn't matter!
) then with my more sedate riding style now, they will last alot longer. ZERO clutch slip now even with two up riding, full bags, ect. I was VERY careful on reassembly to avoid hearing the "pop" of the star and followed all the tech tips. OEM fibers and springs seem to run along the same lines as fork seals, OEM works best.
